SSW LT Headers HP Gains?
Old Feb 3, 2013 | 05:29 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
I have f body manifolds on the car right now that merge into a Y pipe with no cats. Hawks is having a deal on the 1 5/8" headers and Y pipe "package" and im wondering if it is worth the $800. Any clue how many pony's i could add to the stable with this set up?
Old Feb 3, 2013 | 07:26 PM
bungy74's Avatar
Car: 1992 Camaro Z28
Engine: 5.0 TPI
Transmission: auto
Re: SSW LT Headers HP Gains?
Just an FYI, I am going to buy some headers soon too. I called Hawks and the 1 5/8 are not made by SSW. I will probably go with the 1 3/4 as they are SSW.
Old Feb 3, 2013 | 08:04 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
I often wondered why the 1-5/8 headers looked polished while any other header offered by hawks is raw stainless. Guess we now know.
Not sure of HP gains, but it is generally accepted that ls motors respond well to exhaust upgrades.
Old Feb 4, 2013 | 03:49 AM
Brando5641's Avatar
Yea i know the f body cars will gain around 30hp, but that is going with ORY and i wonder if a lot of that comes from loosing the cats. If it was worth 20hp to go from stock manifolds to lt headers i would do it but i have always wondered if most of the gains are comming from not having cats + getting rid of that smashed pipe they call a y pipe... I am asking this because i am catless and have a decent y pipe already so im just wondering what the LT's alone will do.
Old Feb 4, 2013 | 09:44 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
i would skip the little 1 5/8" tubes and go with the hedman husler mids....1 3/4" primary tubes that are coated, shipped to your door, for a lot less money.
mids and lt's will show you a lot better bottom end torque. how much hp/tq you gain depends on your combination.
Old Feb 7, 2013 | 07:17 PM
Brando5641's Avatar
http://api.viglink.com/api/click?for...13602859542862
there is the link for the hedman headers if anyone diggs this up later
Old Feb 9, 2013 | 09:48 PM
hicksport's Avatar
Car: 1991 vert camaro
I know the headers that I used arent the ones your looking at but in my swap I had shorties with no cats and a 3 inch mandrel bend cat back. I bought Hawks full system: 2 inch primaries and 3.5 inch cat back system complete kit. I went from 391 rwhp to 432rwhp the tourque picked up as well all the way across the RPM range. I'd go for longtubes and dont be scared of bigger tubes.
Old Feb 10, 2013 | 12:59 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Ive seen ppl barely lose hp if they are using good high flow cats. I think alot has to do with y pip design interms of pipe size and how the bends are done.Going to long tubes generally picks up hp and torque across the board.
Old Feb 11, 2013 | 08:16 AM
Car: 91 Z28
Engine: 6.0L LQ9
shorties aren't any better than running the late model exhaust manifolds. to compound the issue, if your shorties had 1 5/8" primaries, that is also a bottle neck......
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
