Watch a Rookie Learn How To Swap a LS1 and T56 into a 1992 Z28
Old May 29, 2025 | 11:47 AM
  #301
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Watch a Rookie Learn How To Swap a LS1 and T56 into a 1992 Z28
I would verify the pressure at the rail. A walbro 255 should be more than enough to get your combo started.
Old May 29, 2025 | 12:06 PM
  #302
Warnd's Avatar
Car: 1992 z28
Thank you, I will do that. I will get the gauge hooked up and verify. Do you think it is possible I damaged the starter from trying to prime the engine? It did pass at the parts store, but I am not sure I trust the guy that did it lol.
Old May 29, 2025 | 12:15 PM
  #303
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I mean its possible, but if it turns the motor over i'd say its doing starter things.
Old May 29, 2025 | 12:27 PM
  #304
johnw999's Avatar
You also mentioned having trouble with your hatch. Here is a crazy thread on a 1991 Z28 with a hatch release button that actually started the car. He did an auto to T5 swap and didn’t rewire hatch release pickup from the starter wire to the parking brake ground. Maybe there’s something there.
https://www.thirdgen.org/forums/elec...ch-starts.html
Old May 30, 2025 | 10:00 AM
  #305
Warnd's Avatar
Car: 1992 z28
Hmmm that is very interesting indeed...definitely gives me something test/troubleshoot. Thank you for the suggestion!
That definitely explains the intermittent behavior from the starter, but maybe I have more than one problem, because after I jump the starter directly, the car should at least stay running.
Buggy Disaster
Feb 19, 2017 04:09 PM
galletti
Jul 11, 2009 07:22 AM
JerseyMark
Jan 7, 2006 02:19 PM
Diabolical
Oct 22, 2004 02:04 PM
RSRagtop
Jul 31, 2002 04:24 PM
