Lt1 acting weird when it rains?
Old Aug 2, 2013 | 06:20 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Every time it rains my lt1 acts like it wont start 80% of the time, I don't drive it every day, maybe once a week tops. The other day it rained here about an inch, i go out to start it and nothing, it just turns over. So i wait a day or two for it to dry up, go back out and it fires right up and runs like nothing happened .
I think moisture is getting into the optijunk somehow. I checked the waterpump and it's not leaking. Again it only pulls this **** when it rains i noticed? I did a Google search for the problem and a couple of hits just like my question, but a bunch of vague ******* responded.
Old Aug 2, 2013 | 07:08 PM
86gn's Avatar
Car: 92 Vert
Re: Lt1 acting weird when it rains?
Three things seem to always be the problem with LT1s ...icm , coil, or the everpopular and most likely the opticrap
Old Aug 2, 2013 | 07:18 PM
89rs454's Avatar
Car: 1989 SS
Yeah..the optijunk... oh god could i kick the man in the nuts who designed that. Anyway i will investigate it further tomorrow. The sad thing is it's not even out in the open, my car is parked in a small barn.
Old Aug 2, 2013 | 07:45 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
sounds like a optispark issue
Old Aug 2, 2013 | 09:06 PM
89rs454's Avatar
Car: 1989 SS
I love the optispark dizzy, more then likely it's the coil getting wet. crosses fingers.
Old Aug 3, 2013 | 08:26 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Opti isnt as bad as it seems. ya a PITA if ya get it wet.
Good read on the opti system
https://www.facebook.com/OklahomaCor...64600993707188
Old Aug 12, 2013 | 11:07 PM
89rs454's Avatar
Car: 1989 SS
Thanks for that. It did it again, it's been raining for the past 3 weeks here. When it dried up for a few hours i put a shop fan on it for about an hour, and it fired right up and ran about a 13.999 down the road, pulled damn hard like nothing happened.
I can't suck through none of the two vented lines to the opti, should i be able to is the question? I thought the vented vacuum lines was supposed to fix this bs. I just dread paying 360$ for something that wants to work when it feels like it.
Old Aug 13, 2013 | 06:18 AM
Car: 89 formula 350
I bought a cheap one on ebay recently for $80 and it worked fine. Made by the same company that made my OBD2 distributor that I used for 3 years.
Old Aug 13, 2013 | 11:53 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Probably the opti. I ran my old one for around 4 years no issues. Solution seemed to be, buy a new AC Delco unit, take it apart and loctite the screws inside then use RTV to seal the case.
It was used on my 383 N/A 3 years then on my turbo setup. Never an issue. Also I have power washed the motor, driven it in the rain etc.
Jay
Old Aug 24, 2013 | 11:21 PM
89rs454's Avatar
Car: 1989 SS
Update: it's been dry for about 3 weeks, no problems i guess i will postpone a new opti until the next thunder storm hits. Will keep a close eye on the radar. Thanks guys for the input.
Lbibb
May 5, 2016 12:00 AM
3.8TransAM
Oct 1, 2015 07:47 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
