lt1 swap throttle cable 1992 camaro
Old Nov 20, 2013 | 01:31 PM
c4mo's Avatar
After doing some research on the forum i found that a 1992 camaro tpi throttle cable would work, so i ordered one from oreillys that i found to be too short. The car is a 1992 camaro rs that was orginally tbi 305, im swaping in a 1995 lt1/t56. At this point im a little lost, does the cable bracket need to be moved back or do i need to get a cable from another application? Thanks
Old Nov 20, 2013 | 01:43 PM
c4mo's Avatar
Re: lt1 swap throttle cable 1992 camaro
https://www.thirdgen.org/forums/ltx-...en-vs-4th.html
Judging by the picture i have third gen pedals in the car.
Old Nov 20, 2013 | 01:47 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
I used a universal braided steel throttle cable. I welded a fender washer over the original hole in the the fire wall to step the inner diameter down to a usable size.
Old Nov 20, 2013 | 05:02 PM
88monteSS's Avatar
Car: 92 RS/97 K3500/07 ISS
Engine: LT1/454/LS4
Transmission: 4L60E/4L80E/4T65E-HD
Axle/Gears: 2.73/4.10/3.29
I used the cable for a '93 z28. It took a little modifying to get it to fit the hole in the firewall correctly (iirc it's narrower than the '92 setup), but it works perfectly.
Vintageracer
Jan 10, 2020 05:33 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
