Cam Question in 5.3l
Old Dec 14, 2013 | 02:37 PM
Cole Curtis's Avatar
Car: 82 camaro z28
Engine: 305 crossfire...soon to be 5.3l ls1
Transmission: 2004r :( I need a new one
Axle/Gears: 3.43 10 bolt I think
I purchased a 5.3l block for my swap into an 82 camaro and the guy "threw" in a ls1 cam for free. My question is how will this cam work in 5.3l and is it worth putting in or getting a custom grind. I've looked up the part and grind # to no avail. I know a little bit about cams but not that much and I find it weird the intake and exhaust are the same? and what kind of hp gains could I expect over a stock cam or another custom grind?
Specs: part# 54-000-11 grind#: 13117r/13117r
gross valve lift: I-.598 E-.598
Duration @ .006 Tappet lift 275 275
duration @ .050 I- 226 E-226
lobe lift I-.3520 E-same
Lobe separation 113.0
Old Dec 14, 2013 | 02:54 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Cam should be one of the last components u buy for an engine build .. Ur cam needs to match ur heads, intake, compression etc.
Old Dec 14, 2013 | 03:00 PM
Car: 82 camaro z28
Re: Cam Question in 5.3l
I didn't buy it...it was given to me with the motor. And I do realize this the motor is going to be completely stock short block and heads. Intake will be ls1(ls6 if I can find one for cheap enough) and down the road probably this summer have a turbo turning low boost and a cam I was wondering if this one I had would work. Also curious if its a big cam or a small cam and how streetable it would be.
Old Dec 14, 2013 | 03:04 PM
1gary's Avatar
Cole-there is a section for this in the engine swap section where you might get better answers.
Old Dec 14, 2013 | 03:17 PM
Car: 82 camaro z28
ah ok thanks
Old Dec 14, 2013 | 07:32 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Not a great choice at all for a boosted motor
Sure it will still make power but-
If it were me Id use the truck intake if theres room youll get more torque out of that 5.3. They flow pretty darn well plus they cost as much as dirt
Old Dec 15, 2013 | 06:02 PM
Pocket's Avatar
Car: 91 Trans Am
For a totally stock setup, that cam is a small bump above the tiny truck cam. If its free, rock it. If you're turbo'ing later, pick a cam to match at that time
Old Dec 15, 2013 | 07:05 PM
Car: 82 camaro z28
Hmm ok yeah so I'll probably go get a custom grind then and the issue is I'm pretty sure there won't be room with the intake as its really tall. Would there be any noticeable hp gains from this cam?
Old Dec 16, 2013 | 09:19 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
best bet to find any gains with a stock LS1 cam in a stock 5.3 is to check on LS1Tech and even youtube for any dyno vids. Its not alot but its better than the 5.3 cam if your not going to do anything else to the engine.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
