Truck Alternator + F-Body Bracket
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
Hey all - finally got the motor in for mock up and drilled and tapped the block for the fbody alternator bracket. Was excited to get it bolted on but ran into this (see pic).
Anyone running a large body truck alternator on a third gen swap? The back of alternator and charge post hit that kmember brace.
Ideas? Note the alternator still needs to go back about a half inch.
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Re: Truck Alternator + F-Body Bracket
I am running one, but with a tubular k-member. I would notch or remove the brace to get it to fit. Most of the tubular k-members I have seen do not have the brace anymore, unless you go with the road race unit so I would say go without it.
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Remove the brace. If you have a spohn K-member, you must cut the bracket off
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
I figured removal was the solution. That brace looks pretty flimsy anyways. Thanks for the help guys!
Car: 92 Firebird
If using a low mount AC compressor, the pass side bracket goes away as well
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
No AC for me! Because RACECAR! lol
But seriously - can't believe all the room with the HVAC out of the way!
I notched my brace.Didnt need much cut off
Hotrodboba400
12-10-2019 07:07 PM
