Another LSX/th350/turbo question thread
Old Jan 24, 2014 | 09:04 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
So I bought another 3rd gen..a 91 RS thats backhalved, cage etc etc. I figured I'd do the low budget thing so I bought a 2004 LQ4 out of a pickup + TH350 + s480 turbo to see what it does just like that.
My questions:
Since I'm going to do a carb'd setup, I know I need a victor jr and a MSD 6010. What part of the harness needs to be saved?
I'm ONLY going to run a water pump and alternator. Is there a cheap bracket made for this already or should I just keep the truck alt bracket (I have a 4" cowl hood so fitment isnt an issue I think).
On the TH350, since I have an '04 LQ4, I'm guessing I dont need an adapter? Do I need anything to bolt up my convertor to the flexplate?
I have no mounts on my k-member so if I buy the mounts from Hawks Third Gen (who never answer emails), with solid motor mounts, does it place the LQ4 in the same spot a old SBC sits? I'm asking because I want to know if my trans will move back or forward a few inches or if it will sit in the exact same spot.
On the turbo stuff.. I wanted to use the truck manifolds, mine sweep back and not down, since I cant... do any of these fit or think they would:
http://tinyurl.com/q5qolpd
or
http://tinyurl.com/no8ezot
Old Jan 24, 2014 | 11:17 AM
gbeaird's Avatar
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
Re: Another LSX/th350/turbo question thread
We're putting a LS1/TH350 into our 85 Firebird. We're running an old Spohn TH350 transmission crossmember and torque arm. It's what we had with the SBC/TH350 before, so we're reusing it. The TH350 doesn't move, and we used Dirty Dingo billet aluminum motor mount adapters (DD-LS-DOUBLE-D
IIRC), bolting our solid SBC engine mounts to them. The engine and transmission dropped right in and bolted right up with no problems.
For the transmission-to-engine mounting, you'll need a LS-to-TH*-specific flexplate. We're using a TCI flexplate: TCI-399753. It comes with a spacer that sets in the center of the flexplate and holds the '****' on the converter in place. In the description I read, I was lead to believe that the flexplate doesn't come with crankshaft mounting bolts, but it does. I did order some ARP bolts, and used those, but the flexplate does have crankshaft mounting bolts.
When bolting the transmission to the engine, there's one bolt on the passenger side you won't use, and the bolt holes in the oil pan will go unused, but that's okay, just use all that you can. Oh, and if you're replacing a SBC with that LQ, the bolts won't work. The LQ4 will require a metric thread bolt (8mmX1.5 thread, I believe).
Old Jan 24, 2014 | 04:15 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
so then I just need those brackets on my kmember and then old school SBC solid mounts that go to the block?
I thought I didnt need the spacer since my engine is an '04. Thought only '99-'00 engines needed that?
Here is my flexplate, it had a 4l80e 4x4 trans bolted to it. Im assuming the spacer is there?
Attached Thumbnails Another LSX/th350/turbo question thread-flexplate.jpg
Old Jan 24, 2014 | 04:58 PM
Pocket's Avatar
Car: 91 Trans Am
My questions:
Power and gauges. Read the harness prep thread in the LS1 swap sticky
Do a search on LS1tech, pretty common conversion by adding an idler. You can also build a custom bracket without much effort. I wrote a how-to in my budget swap thread
Already has the adapter. In the pic, its behind the flexplate
No, the conversion LS1 stands bolt in the V6 mount position and use LS1 clamshells on the block. If you want a cheaper, DIY method, look up 1" setback plates and print out a diagram. Alternatively, you can do the alt bracket and mounts in one shot with a motor plate
Not directly, but you can cut up and MIG weld the truck manifolds easily. They dont weld like old cast iron
I have seen one fellow use the cheap headers with minor mods
Id recommend a DIY venture on the hot side stuff
Old Jan 24, 2014 | 10:28 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
Pocket:
thanks for the clarification.
On the harness, I'm only going to use Autometer gauges, not factory gauges that come with a Camaro. So I only need oil pressure, water temp, volts, etc. Does that simplify how much of the LS1 harness I actually need for use with a MSD 6010 ?
On the flexplate, do I need to buy one that lets me bolt the TH350 convertor to it?
I'll look up the truck manifold welding..I saw a thread on it. Thanks again!
Old Jan 25, 2014 | 09:37 AM
Pocket's Avatar
Car: 91 Trans Am
You dont need any of the LSx harness for a carb conversion, only the 3rd gen half cut down
For the new gauges, Id reuse the factory wires passing through the firewall to save from extra holes. If you're dumping the dash and as much wiring as possible, Id build a simple switch board and remove all the OEM wiring
Old Jan 28, 2014 | 09:53 AM
gbeaird's Avatar
Axle/Gears: 9" 3.73
The Dirty Dingo brackets bolt to the block. Then the engine side of the Moroso solid motor mounts bolt to the DD plate. That's the configuration we're using.
I am not sure about your 4L60E flywheel. It may work. We had nothing to start with. The back of the crankshaft on our LS1 looked similar, but w/o some measurements, I have no clue if you can get away w/o an adapter. The shape was similar, but the ID of the crankshaft end is a bigger diameter than the snout on the converter. That's why you need the adapter. That, and our new flywheel mounted the converter so it sat back from the crankshaft a bit, so the adapter is necessary to make up that space.
Old Jan 28, 2014 | 11:45 AM
Pocket's Avatar
Car: 91 Trans Am
The 80 flex plate can be used with older 60's, not the LSx version. Bear in mind it's a 6 bolt vs the 60's 3 bolt
Old Jan 28, 2014 | 06:51 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
I bought these from DD:
http://dirtydingo.com/store/product_...oducts_id=1322
So basically I just need the frame mounts and thats it, I'm assuming.
gbeaird:
Mine has the adapter already. As far as my flexplate, all I need to do is round out the holes for the converter bolts and I should be good to go.
Old Jan 30, 2014 | 02:31 PM
gbeaird's Avatar
Axle/Gears: 9" 3.73
Those may work. Here's what I used with Moroso solid motor mounts:
http://dirtydingo.com/store/index.ph...=1_206_305_335
and these motor mounts:
http://www.summitracing.com/parts/mo...s/model/camaro
Good to know you're set for the flywheel. Those things aren't cheap!
Old Jan 30, 2014 | 03:19 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
I'm assuming that with the stuff I bought that bolts to my LQ4 block, all I need is the stock k-member motor mount...right?
Old Jan 30, 2014 | 04:01 PM
gbeaird's Avatar
Axle/Gears: 9" 3.73
That's what we used. I would assume the LQ4 is similar to the LS1, but do not know for certain. Hopefully others with better knowledge of the LQ4 specifics can post up.
Old Feb 1, 2014 | 12:44 PM
Pocket's Avatar
Car: 91 Trans Am
Those are for a SBC, so you will have to use the stock SBC clamshells with an adapter plate bolted to the block. Use the 1" setback plates for a stock position
Like these. You can build your own set easily. The bottom bolt for the SBC clamshell lines up with a LSx, move it back 1"
http://www.ebay.com/itm/LS1-Conversi...-/281162117619
Externally, LS1 vs truck blocks are nearly identical. Any mount that fits one will fit the other
Old Feb 1, 2014 | 03:07 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
why would I need setback plates if my motor mounts are adjustable?? You're probably replying to gbeaird instead of me, I think.
At any rate, with what I have + the ugly *** clam shells, I think it should work.
Old Feb 4, 2014 | 03:08 PM
gbeaird's Avatar
Axle/Gears: 9" 3.73
I actually got a set like that, made from 1/4" steel, just like those. I opted for the DD units as they were aluminum. I'm at weight per our class rules, so want to save as much off the front as possible. The nice thing about those, as well as the DD plates is it'll drop the engine/trans back in the same orientation you had with your previous engine/trans combination. That's a huge plus if you're reusing your transmission (no need to rebuild or replace the trans crossmember unless you have to because of exhaust routing ) which was also important, because the class rules we run under do not allow for much engine relocation (1/4")
But yeah, BDR's adapters will work perfectly for his needs.
Cleotiz
Jan 6, 2018 08:56 PM
Linson
Aug 21, 2015 02:12 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
