Oil pan lsx
Old Feb 15, 2014 | 02:12 PM
ambainb's Avatar
Car: 86 iroc
Engine: Iron 408 LS3 combo
Transmission: Ram10 T56
Axle/Gears: 3.73 10 bolt :)
Oil pan lsx
Hi, what oil pan is best for clearance in these cars? Swapping a 408 lsx . It seems that te gm retro fit one still hangs to low? Will I have to do any cutting with a stock f body pan? And will the f body windage tray clear a stroker ? Any help would be appreciated
Old Feb 15, 2014 | 02:52 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Oil pan lsx
LS1 Fbody fits great, C6 LS2/3 pan fits better, but only if you have a tubular K-member
Shim the windage tray with a few washers to clear the crank. Fbody pan will require light grinding inside to clear the first journal of rod bolts
Old Feb 15, 2014 | 03:41 PM
ambainb's Avatar
Car: 86 iroc
Re: Oil pan lsx
Awesome thank you for the quick replie
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
