Let's see your LS1 PVC systems
Old Apr 9, 2014 | 10:13 AM
blakecharles's Avatar
TGO,
I'm just about done with my LS1 swap and am contemplating what to do about the PVC system.
- I really don't want to delete it and just run the breather
- I can't run the LS6 valley cover
All the swaps I've seen locally have the PVC setup with no catch can... Is this needed?
Can I see some of your setups?
Old Apr 9, 2014 | 10:16 AM
Re: Let's see your LS1 PVC systems
this is basically what I made with 3/8" fuel lines, and a hand full of Help and Dorman parts.
Is the catch can needed?
Old Apr 9, 2014 | 10:18 AM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
https://www.thirdgen.org/forums/ltx-...ort-silly.html
Why I argue for duals, but a street car can get by with single.
Congrats on hitting a thousand posts!
Old Apr 9, 2014 | 11:50 AM
Ha! I didn't even notice! My setup is DBC. I'm running the Lokar LS1 cable from Hawks with a Lokar throttle cable bracket with the TPI firewall gourmet.
Old Apr 10, 2014 | 07:17 AM
Pocket's Avatar
Car: 91 Trans Am
Move the PVC to the drivers valve cover and run it like the diagram. Inline valves gum up quicker than traditional vertical valves. If you notice excessive oil consumption between oil changes, swap the PVC for a fixed orifice tube from a newer truck
Old Apr 10, 2014 | 08:16 AM
WTR388's Avatar
Car: 87 Trans Am
I'm currently cleaning up the motor... I was just going to leave the PVC as is with the connections on each Valve cover ending at the intake manifold.
I have the LS6 intake.
Old Apr 10, 2014 | 01:34 PM
okay so most defiantly run a catch can then? all of the swaps I've seen around here have no catch can.
Old Apr 10, 2014 | 01:58 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Yes, closed system with can:
Your PCV system should be closed. Do not use a breather on the catch can or valve cover as it allows for unmetered air to enter the engine and makes the PCV system function improperly and less efficiently.
The intent of the PCV system is to reduce crankcase pressure manifested from blow-by during the engine cycle. Engine vacuum is much more efficient at drawing these gases out of the crankcase than venting to atmosphere. This also creates a small vacuum on the crankcase that does slightly improve ring seal and power output. The final benefit is the environment. A closed PCV system recirculates the blow-by gases rather than releasing them in the atmosphere.
Concerning the construction of catch cans; the internal construction is critical. If the can is empty, it's not doing anything to catch the vaporized fluids from the crankcase. In fact, there are very few catch cans with an effective internal design to function properly. Check out this link: http://www.saikoumichi.com/OCC_explanation.htm This is how an effective catch can is designed internally.
Old Apr 10, 2014 | 03:04 PM
this is exactly what I needed to know!
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
customblackbird
Oct 1, 2015 04:30 PM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
