Use 4th gen k member on 3rd gen?
Old May 2, 2014 | 08:38 PM
cheronobyl's Avatar
Car: 1989 Pontiac Firebird
Engine: 5.7l LT1
I have both a stock 3rd Gen and a stock 4th gen k member. If I can use the 4th gen k member I am tempted to just swap the whole thing under my 3rd gen. Is this doable? Or am I crazy?
Old May 2, 2014 | 09:37 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
Re: Use 4th gen k member on 3rd gen?
try it, its probably the only way to find out, but you wont be able to use the stock springs, unless your talking about swapping everything right over
Old May 2, 2014 | 09:56 PM
cheronobyl's Avatar
Engine: 5.7l LT1
I'm saying literally the entire front system, including engine mounts, steering rack, suspension, a arms and more.
Old May 3, 2014 | 02:28 AM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Anything possible with the right mind and tools
Is it a direct bolt on then answer is no
The two are totally different
Old May 3, 2014 | 02:40 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Name:  1004gmhtp_09_ogen_iii_chevy_camaro_suspension_upgradesk_member_comparison_zpsvojmdic2.jpg
Old May 3, 2014 | 03:04 AM
cheronobyl's Avatar
Engine: 5.7l LT1
Forgive my ignorance, but what are you trying to point out via the images?
Old May 3, 2014 | 03:11 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Difference between k member and suspension setup
Above is 3rd gen below is 4th gen
Old May 3, 2014 | 06:55 AM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
might be a better option to go tubular and upgrading the stock suspension. Would be simple and easy as well.
Old May 3, 2014 | 04:53 PM
cheronobyl's Avatar
Engine: 5.7l LT1
I would if I had the money.
Old May 3, 2014 | 04:57 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
What's your main purpose for swapping over k member there are other options to reach your goals that are tried and true
Old May 3, 2014 | 05:11 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Simple answer: not possible. completely different. not worth the time or money to try and make it fit.
Old May 6, 2014 | 02:33 PM
cheronobyl's Avatar
Engine: 5.7l LT1
Okay, so if I cannot I won't. Honestly I was just hoping I could be lazy enough to just bolt the k-member, engine and all, into my third gen. Since I cannot, where does this A/C notch I keep hearing about go?
Old May 6, 2014 | 02:48 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Search Google images you can get better idea of notch
Search K member notch thirdgen
Old May 6, 2014 | 07:30 PM
Pocket's Avatar
Car: 91 Trans Am
If it were that easy, dont you think it would be a common occurrence?
Old May 7, 2014 | 05:44 AM
cheronobyl's Avatar
Engine: 5.7l LT1
Very true, but hey, never hurts to ask.
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
sreZ28
Aug 14, 2015 07:48 PM
