T6 frame turbo folks..where did you put yours?
Old Oct 14, 2014 | 07:43 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
So anyone with a big T6 turbo..where did you mount yours? I'm fixing to start fabbing up my turbo kit and want some ideas where to put my turbo. Is your housing divided or not? If divided, did you just say screw it and do a merge into 1 pipe? I dont think it matters much unless you are putting down big #'s..thoughts appreciated...
Old Oct 14, 2014 | 07:58 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: T6 frame turbo folks..where did you put yours?
Could move rad forward and mount in front of motor. Seen a few done that way
Old Oct 14, 2014 | 09:06 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I cant seem to find any pics of my first setup but it was in the passenger side battery tray. I had a short rad in place that stood straight up.
Then I went overboard and did this lol.
Jay
Attached Thumbnails T6 frame turbo folks..where did you put yours?-dscf0006-4.jpg   T6 frame turbo folks..where did you put yours?-dsc01375.jpg
Old Oct 14, 2014 | 09:44 AM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
@Jay:
LOL! Yea...that looks crazy. BTW.. I'm a noob at fabricating so I wont be moving my radiator. Just about done with my newbie welding class..got a MIG welder from a friend and will fab up my own stuff. I *was* going to use truck mani's but got a set of JBA shortys and cut off the ends and will weld v-bands to them when they get in. My battery is relocated already so I do have room in the front. I was just wondering how you guys were supporting the turbo.
EDIT: your turbo in the first pic ...is it just sitting there being held up by the tubing coming out the headers?
Old Oct 14, 2014 | 10:25 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You definately want to brace a t6. Making a bar go across from frame to frame rail works with a bracket to bolt to the t6 flange.
Old Oct 14, 2014 | 11:02 AM
Jay_rich's Avatar
Car: 1987 Z28
In the first picture that was more or less mock up. The second picture you can see a brace coming out with a bolt. I welded a long nut to the top of the turbo flange and bolted it in. You need to brace them as they are 50+lbs. I think mine came in around 56lbs!
Then your only option will probably be the battery tray. You may have to get creative. there is a guy on yellowbullet and ls1tech that has a pretty sweet setup. He mounted it under the drivers side battery tray. But that would probably require a scavenge pump to get the oil back to the pan.
Jay
Old Oct 14, 2014 | 12:33 PM
BDR's Avatar
BDR
Car: '91 Camaro
Engine: Mild 283
Transmission: TH400
@Jay
Where did you get the oil feed from and where is your return? If I dont have to tap the pan for a return, that would be cool. I may need to swap pans, so if I DO have to tap the pan, its no big deal. I would LIKE TO have my turbo mounted where yours is at or a little farther to the passenger side. Dont know if it will work without moving the radiator forward.
@Orr89RocZ
How is your car running? I read a while back you swapped engines.
Old Oct 14, 2014 | 01:51 PM
Jay_rich's Avatar
Car: 1987 Z28
I got the oil feed of the port just off the TB shown below. Just drill and tap it 1/8 NPT.
The Drain I went into the pan. On my current build I will be taping the front of the timing cover. Im running a vette ATI balancer without the AC pulley on the back so there is plenty of room. I didnt wanna drill and tap a shiney new oil pan lol
Jay
Old Oct 14, 2014 | 08:06 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Oh two year ago i refreshed motor with new top end, cam and turbo setup. New efi. Got it running last year and tuned. Raced this year but had to fix heads after a small issue and blew tranny once early in summer then again last week lol. Got a new one in today. Looking for mid 8s this weekend
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
