LT1 w/6 speed vs 5.3 with 4l60e
Old Jan 3, 2015 | 05:59 AM
mackjar66's Avatar
Car: 1989 GTA
Engine: pending install 383 tpi
What's your guys opinions?
2003 2wd Silverado whole truck for $1200 has the 5.3 150000 miles
Vs
1994 trans am LT1 w/6 speed 101k whole car with leather interior $2000
Old Jan 3, 2015 | 06:44 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: LT1 w/6 speed vs 5.3 with 4l60e
I'd go with the lt1 because I want a six speed.lol
Old Jan 3, 2015 | 06:53 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
There are strong opinions for both sides. Logic says 5.3l for just about every reason except if you want a manual transmission. Tough call. You could buy both, install what you want and part the vehicles out to possibly cover the cost of both.
Old Jan 3, 2015 | 07:28 PM
zenish's Avatar
Engine: 305 tbi
the lti six speed is supposed to work with the 305/350
Old Jan 3, 2015 | 07:30 PM
mackjar66's Avatar
Car: 1989 GTA
Love the idea of a 6 speed. hard to pass up LS power
Old Jan 4, 2015 | 12:34 AM
ledman66's Avatar
Car: '85 Trans Am
Engine: 305 LG4 4BBL
I'd say go with the LS1
Old Jan 7, 2015 | 08:52 AM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
do you drive the car everyday? 5.3/4l60e
i did the ls/6 speed thing, wish i would have stayed automatic now, but the ls/lq platform is definitely worth the time.
the lt1 will be a bit easier to install on the front side. your budget, skill set, and future plans should dictate your decision.
Old Jan 7, 2015 | 09:29 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
5.3 for boost. I'd lean towards lt1 for na power
Old Jan 7, 2015 | 04:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you like the idea of the 6 speed, that's probably the way to go. It'll be a little more work, since you currently have an auto tranny (I assume), but still less work than installing the 5.3.
And, less expensive. Especially when you consider what else you could get off of the TA either to use or sell. You won't need anything else to install the LT1 between 3rd gen parts and the 4th gen donor car. Keeping AC will present a bit of a challenge (if you're planning on that). You'll need to do some PCM tuning, to eliminate VATS, for instance.
Installing the 5.3 would require more parts, like intake, oil pan, exhaust, torque arm mount, front end accessories, plus the usual swap parts like mounts. You could basically wire the engine/trans into the car by judicious clipping of the donor truck harness. But truck LS engines use a mechanical radiator fan, so you'll have to tap into the PCM connector to get that function (or wire up a mechanical fan switch). And PCM programming, again.
For the record, I love the LS platform, but that doesn't mean the LT1 isn't viable.
New2Chevy
Sep 28, 2015 12:35 AM
Amillionoh7
Sep 11, 2015 11:36 AM
L0tuS
Sep 4, 2015 11:16 PM
IROCZ1989
Sep 4, 2015 11:54 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
