How much HP is too much for a t-top car (structurally)?
Old Apr 11, 2015 | 07:44 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
I'm in the process of building a turbo LQ4 for my 1984 Trans Am with t-tops. I'm already upgrading all the suspension including adding subframe connectors. I'm also going to install a BMR trak pak torque arm kit to get the stress off the tranny tail shaft. At what HP level should I be concerned with cracking my sail panels or stressing the unibody? Would a four point roll bar help at all or does it really not matter since the car has no actual frame?
Old Apr 11, 2015 | 09:18 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: How much HP is too much for a t-top car (structurally)?
SFC's will dramatically increase the chassis stiffness.
Stock hard tops tend to crack at the sail panels. I don't think you'll need anything with SFCs as long as you really aren't launching hard.
Old Apr 11, 2015 | 10:01 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
2,000 rwhp
Old Apr 11, 2015 | 11:07 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
This is true, when I had my 'Z' painted there were tiny fractures about 1/8" long at the top of the B pillars that were welded up by the body shop. Mine is a hard top car with an original L98 engine. SFC's are a must on these cars, then HP is a non issue.
Old Apr 12, 2015 | 12:03 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Originally Posted by TTOP350
2,000 rwhp
Old Apr 12, 2015 | 06:41 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Really hard question to answer. Put subframes and or a rolld cage in it. You wouldnt put a big power motor in any car and forgo the suspension/chassis mods would you?
Old Apr 12, 2015 | 07:45 AM
battmann's Avatar
No. I was hoping to not put a roll bar in though. I will if need be, but wanted to limit it to a 4 point bar. This will mainly be a street car so I didn't want bars in the way of the doors and at the t-top edges. I was hoping suspension upgrades will be enough.
I already purchased all these parts except the brakes:
  • UMI tubular a-arms, adjustable panhard bar, adjustable lower control arms, wonderbar and caster / camber plates
  • Hotchkis subframe connectors
  • BMR Trak Pak torque arm setup (I'll weld the crossbrace to the subframe connectors)
  • Koni yellow shocks & struts
  • Brakes: LS1 or C6 kit from bigbrakeupgrade.com
Here's my build threads if you want to see more:
Overall thread
Engine only thread
Old Apr 12, 2015 | 08:02 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Some guys are running both inner and outer SFCs, I'm inclined to do the same. Mine's T-Top also, and I want to end up around 1200 HP. Inners are Mac or Alston, TopDownSolutions has them. Just about all the other brands are outers.
Old Apr 12, 2015 | 09:03 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Only seen cracks on b pillars on hard top cars....
I have both Alston & Spohn... each and both made a noticeable difference...
I don't have tons of power, but do have t tops.... (tons of other mods)...
The Spohn torque arm also made a big difference.
Old Apr 12, 2015 | 11:04 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
I had cracks on my b pillars. Mine t top. If you dont want to do a cage at least min do subframes.
Old Apr 12, 2015 | 06:07 PM
92BLKL98's Avatar
One thing I love about my SFC's is the ability to single point jack the car to get both wheels off one side of the car. Kind of nice if you do a front to back rotation on a car with the same size tires all around.
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
3rdgenparts
Aug 6, 2015 09:03 AM
