Power wire for fuel pump?
Old Feb 25, 2016 | 05:59 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
I've finally made it to the last part of my swap... Wiring. I've pretty much nailed down a game plan on getting this thing finished but have a couple questions.
Which wire powers the fuel pump? By the diagram I have it shows a Tan/White wire on the C100 as the fuel control. Is this the one I need to hook my Painless fuel pump power wire to?
Also, for a 12v switched power source. Would it be better to use the large pink coil wire from the C100 or to locate a fused wire on the C207 under the dash? This harness gets 12v constant from the starter lug, so that part is easy...
Other than those couple things the rest is easy... Hope to have this new motor fired up this weekend if possible.
Old Feb 25, 2016 | 07:19 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Power wire for fuel pump?
Correct, the TAN-WHT colored wire is the fuel pump B+.
Yes, you can grab switched power from the old PNK coil wire. It is on a fusible link so just be aware if it blows that you're replacing that link rather than a more simple job of replacing a fuse.
Old Feb 28, 2016 | 09:13 PM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Thanks, we got it wired up and working great. Appreciate the help!
Old Mar 13, 2016 | 12:58 PM
Pocket's Avatar
Car: 91 Trans Am
Yup, the C100 holds the FP wire for 88-92. Earlier cars with an in-tank pump had it in the C207
12V IGN for the fuseblock or any stand alone can hook into any pnk wire on the car. Since you've got alot of stuff near the C207 already, Id use one of those. Doesnt matter which, they all should have 12v IGN
Spaceboy1980
Feb 18, 2016 07:06 PM
Drone358
Feb 4, 2016 01:22 PM
mrestrictrplate
Jan 31, 2016 03:47 PM
Gunner242
Jan 30, 2016 10:42 AM
evilstuie
Jan 29, 2016 04:14 PM
