T5 to LSX?
Old Aug 1, 2016 | 08:08 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
T5 to LSX?
So I've already done a search and everything says you need a 621 bbc bellhousing to mate a t5 to an lsx and I already know these aren't the strongest transmissions in the world. I've got a buddy whos helped a friend do a 4.8/t5 swap into an 80s regal and they both say he's using a sbc bellhousing with an lsx clutch. He said the only modification he had to do was elongate some of the bellhousing or tranny bolts and some spacer for the crank I believe. His 4.8 is stock and the t5 is holding up fine. Has anyone else heard of this setup using a stock sbc bellhousing??
Old Aug 1, 2016 | 04:48 PM
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Re: T5 to LSX?
A sbc bell housing will bolt up to an ls, all but one bolt. Its been a while but my father n law has a built 700r4 behind his ls in a jeep and it bolted up fine with the stock sbc bell housing. He did have to use a different fly wheel and I believe that it had a spacer built in to.
Old Aug 1, 2016 | 05:16 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: T5 to LSX?
Pocket worked on this a while back. Post 2 has a bunch of usefull info. https://www.thirdgen.org/forums/ltx-...wap-again.html
Old Aug 1, 2016 | 06:44 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T5 to LSX?
Keep your eyes peeled for a used. Lakewood 15020.
It keeps everything T5 thirdgen compatible.
The 621 lacks the mounting angle of the third gen.
Old Aug 2, 2016 | 07:27 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Re: T5 to LSX?
thanks for all the input! you guys definitely cleared things up for me
Motown
May 18, 2016 08:25 AM
mightymouseman
Feb 7, 2005 08:59 PM
V6sucker
May 13, 2004 01:13 PM
Air_Adam
Sep 10, 2003 08:39 PM
kptkid
Jan 14, 2003 01:30 AM
