From Base to Bad, My 86 Sport Coupe Build Thread.
Old Mar 1, 2018 | 01:06 PM
  #51
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Re: From Base to Bad, My 86 Sport Coupe Build Thread.
OK, so after I went LS, I ran the car this way for maybe a year or so, then I started doing some more upgrades. I went ahead and swapped the 706 heads for a set of 799's that I picked up on eBay. I had a shop machine them down .030, and then installed a set of Brian Tooley valve springs, as well as upgrading the rockers with some Comp trunnion bearings. I also went with some LS9 head gaskets, ARP head studs, Comp hardened push rods, and to top it all off a stage 2 Tick Performance turbo cam. At the same time I sold my LS6 intake and picked up a cathedral port Fast 102 intake and eBay 102mm throttle body.
After this I decided to upgrade from the factory brakes to Cts-V brembo's. I picked the calipers up from a member on Ls1tech, along with the brackets and hoses. I modified and tapped the spindles myself. At the same time I realized that my 17 inch wheels were too small to clear the new brakes, so I picked up a fresh set of 18x9.5 C5 rim's off ebay. I'm running a 275/35/18 tire in the the front, and a 275/40/18 in the rear. I really don't have any pics of this work being done unfortunately, but here's some of the last shots I have of the car before the body work began...
Also I bounced back and forth between the Z28 grid tails, and the sport coupe lights. I put the sport coupe lights back in when I though I was gonna leave the car this way...
Old Mar 26, 2018 | 11:27 AM
  #52
rampageZ28's Avatar
Subscribed! Awesome built man!
Old Mar 27, 2018 | 06:39 PM
  #53
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
I've been following your youtube channel for a few months now and have enjoyed your updates.
I recently installed the same Speed Engineering headers that you did, and also liked how they fit.
If you were closer to Chicago I'd tell you to come by and use my lift anytime!
My exhaust build is here:
Post #462
https://www.thirdgen.org/forums/memb...1z-ls1-10.html
Like yourself, I'm not sure how happy I'll be with the passenger side headers ground clearance......I feel like it'll bug me so I'll have to cut/shorten the header, which I'd really like to do.
Old Jun 20, 2018 | 12:16 AM
  #54
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Post #462
Did you say a lift?? ummmm that just might be worth the drive
Yea they're a good header for the money. Especially since the hawks sit the exact same way, there was no way I was gonna pay a grand to have them scrape along the street... Anyway thanks for the support, youtube's been taking up my time but I will keep adding to this thread!
Old Nov 7, 2018 | 06:45 PM
  #55
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Ok I’ve been busy with youtube, but I need to keep this thread alive! So after the brake swap I decided to get started on body work. Now I’ve always loved the the 90-92 Gfx cars, but the price they we’re going for at the time I got my car, It was just out of the question. Keep in mind when I started this build, I was in my early 20’s working at a tire shop. Now my initial plan was to pick up a good body roller 90-92 and swap all my stuff into it. Well I tracked down a 92 rs with a z28 spoiler and gauge cluster for a 1000.00 bucks on craigslist. After about a 45 minute ride and uhaul truck/trailer rental, I was in it for 1300.00.
After taking a closer look at the car I found rust hiding in a few spots. Aside from this, being I had an entire gfx car, I decided it would just be easier to swap all the gfx pieces and hatch over to my car. Plus my car was a less desirable 2.8 auto, so I really didn’t feel bad about it. I also discovered the roller had a 3.73 posi rear with tubular poly lca’s and panhard bar. The headliner was also in great shape along with the door panels and dash. Also, being it was a 92 it didnt have a speedometer cable, and the previous owner swapped in a 145mph gauge cluster. Plus I had all the gfx pieces and the rocker brackets I needed to swap them over to my car. For 1300.00 bucks, I couldnt be happier with it.
**pics coming soon, Im posting this from my phone and the photos are at home on my computer**
Old Nov 8, 2018 | 05:59 AM
  #56
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Lsxmatt, I'm trying to figure out intake setup on my lq4 swap. Your's looks nice, is that a kit or did you piece together yourself? What upper rad hose are you running to allow the intake to clear under it? I think I saw pictures of your blue car with a nice polished intake on it which looked killer. Any info / help would be great. Intake is my last remaining part to buy
Old Nov 8, 2018 | 07:50 PM
  #57
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Dorman makes an affordable LS2 intake that would work well on your LQ4. I'm not certain, but if my memory serves me, the Dorman uses a bottom half from FAST and top half is Dorman.
Old Nov 8, 2018 | 08:57 PM
  #58
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Thanks for reply but I meant air intake. I already have a manifold setup on my car, need to get an air intake figured out
Old Nov 9, 2018 | 11:50 PM
  #59
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Post #324 should give you some ideas.
https://www.thirdgen.org/forums/ltx-...ml#post5968331
Some people use an intake kit for the LS1 GTO cars if going to the driver side.
Here are more ideas for creating a box.
https://www.thirdgen.org/forums/alte...ml#post6117065
Old Nov 10, 2018 | 02:48 PM
  #60
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
I built it myself with all the parts from intakehoses.com. Its a 4inch pipe. The radiator hose is stock from a 4th gen I believe. You don’t need to run the intake under the hose though. My new setup runs straight across the top of it and the hood closes fine.
Old Dec 11, 2018 | 08:53 AM
  #61
Car: '91 LS6/T56/9"
Engine: LS6
I like the Tahoe, excellent score! Here's a great channel where the guy troubleshoots and fixes many GM clusters like yours:
https://www.youtube.com/user/jeffescortlx/videos
Old Dec 11, 2018 | 10:00 AM
  #62
Car: '91 LS6/T56/9"
Engine: LS6
Tahoe related: I HIGHLY recommend getting the stock transmission temp gauge enabled since you'll be towing. Here's a video on it:
Andy Fanshawe
May 29, 2009 03:46 PM
leeperryracing
Jan 30, 2006 10:15 AM
mw66nova
Aug 21, 2005 01:36 AM
frmns87
Apr 9, 2003 05:04 PM
