Need Advice On Headers and Exhaust
Old Dec 4, 2018 | 06:59 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Been looking at Hawks LT stainless headers, Holley LT headers, Kooks LT headers and Stainless Works headers also. Bottom line: Which is best quality, well designed for install and not hitting everything in sight? I'm probably going with a LS7 in my 85 IROC with a auto trans. Also what Y-Pipe is the best? And how about muffler/tailpipe types,etc? I know this is the LS swap forum and not the exhaust one but I fell I'll get better answers here cause you guys have done this swap before. I need likes, dislikes, and what your experience has been. Pics would be great too. And I'm not concerned about cost. Just want the best exhaust components for my build. Thanks.
Old Dec 4, 2018 | 07:08 PM
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Re: Need Advice On Headers and Exhaust
My vote is for the Holley long tubes, i have the generic 1 inch set back motor mounts, with hawks t56 cross member. Fitment is great. The only thing i had issues with if you even want to call it that, was getting the starter in, but once in there is more than enough room around it. I cant comment on the ypipe because i run an xpipe with duals. Ive heard good stuff about holleys true dual system for 3rd gens, but its only 2.5 pipe. And i cant recall what power levels it will support.
Old Dec 4, 2018 | 07:22 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Thanks for your reply. Power level will be in the 750hp range.
Old Dec 4, 2018 | 07:42 PM
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
No problem man, hope it helps some.
Old Dec 4, 2018 | 07:52 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Holley Blackheart. They are beautifully built and tuck up more than the stainless works.
Old Dec 5, 2018 | 04:39 PM
toddoky's Avatar
I would also recommend the Hooker Blackheart headers...I’m admittedly a little biased.
Old Dec 5, 2018 | 11:04 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Your engine might benefit significantly from dual 3" exhaust. Not easy to package though.
Probably the nicest single pipe exhaust system is the Hawks 3.5" system with 2" primary headers. It is made by Stainless Works for the LS7 and uses V-band clamps. Exhaust tip is hidden behind rear bumper. The 2" headers package much better than their smaller 1-3/4" headers. Only complaint is it tends to tap the passenger side frame now and then. Video below gives you an idea what it sounds like with my 427 stroker LS.
I'm swapping to a Mamofied LS7 so if you can wait until spring then you'll get to find out whether my 3.5" single system is a choke point. It certainly is not a choke point today but I'm about to gain a solid 100 RWHP. These exhaust systems are thousands of dollars so learning from each other can help save a bundle!
Old Dec 5, 2018 | 11:24 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
That's badass. We want more details!
Old Dec 6, 2018 | 08:04 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
I'm in the planning stage at this point. Will strip car and send to paint shop in early spring. I saw that single outlet setup you mentioned, was wondering the same thing. I will start a build thread soon with plenty of pics. In the meantime I'm trying to get a lot of my concerns and questions answered before I start, so I don't learn the hard way. Thanks for your reply.
Old Dec 6, 2018 | 08:06 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Thanks for all of the replies.
Old Dec 6, 2018 | 08:07 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Thanks for your reply. Was looking at them also.
Wild 90
Nov 26, 2014 09:25 AM
Igorealfast
Sep 5, 2011 03:06 PM
keebs98
May 20, 2011 01:14 AM
