Lt1 swap sensor question
Old Jun 1, 2019 | 04:36 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
Trying to finally finish my lt1 swap and im stuck. Putting coolant in the car and its leaking from what looks like a sensor in the block above the oil filter. Anyone know what the sensor is and why its leaking coolant?
Old Jun 2, 2019 | 07:48 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Lt1 swap sensor question
The sensor above the oil filter is for oil pressure. There is no coolant there. Unless you have a oil cooler there and that's not a sensor in the block, it's in the cooler...but I've never seen a cooler have a sensor. My guess is your leak is from above that and it looks like the sensor is leaking. Possibly the crossover tube at the back of the block going from head to head.
Old Jun 2, 2019 | 08:06 AM
Firebat's Avatar
This photo has an interesting note on it about sensors above the oil filter. Got the photo from here: http://shbox.com/1/component_location_views.html
Old Jun 2, 2019 | 08:09 AM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Its a round plug in the block drivers side, it looks to have 3 prongs in a semi u shape and a square piece the coolant is coming out from, i can put my finger on the square passage and stop the coolant leak
Old Jun 2, 2019 | 08:12 AM
Firebat's Avatar
Is it this?
http://shbox.com/1/temp_sensor2.jpg
Old Jun 2, 2019 | 08:15 AM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
No its drivers side of the block, in the block
Old Jun 2, 2019 | 08:20 AM
there's only 2 ports above the oil filter. I have a crusty LT1 sitting in front of me. One is an oil port and the other goes straight through to the flywheel.
Old Jun 2, 2019 | 08:28 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
+1 my GUESS is that it's the steam line leaking coolant,......
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Im pretty sure its right where that freeze plug is
Old Jun 2, 2019 | 08:34 AM
That should be closed. It should be blind and there shouldn't be a sensor in it. Both LT1's I have sitting are like that. Maybe someone did some rigging at some point? The only thing tapped into coolant on the side of block is the drain that got used for the knock sensor. Can you take a picture? It'll probably help us help you.
Old Jun 2, 2019 | 08:38 AM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Yea i know, ive never seen it before. Ill take a picture when i get home this afternoon
Old Jun 2, 2019 | 11:07 AM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Old Jun 2, 2019 | 11:32 AM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Its a block heater, i looked up the number off it and found it online, looking closer at the picture it looks like there is a center screw and its open, i wonder if it just needs closed
Old Jun 2, 2019 | 11:49 AM
I thought you meant the hole near the freeze plug, My mistake. Totally a block heater. Could be loose, could have a bad seal. Not difficult to remove but a pain to install new freeze plug as it sits in the car
sszcam
Feb 6, 2011 12:19 PM
S10Wildside
Mar 17, 2010 01:19 PM
mateo
Nov 3, 2005 06:52 AM
Thirim
May 9, 2004 08:18 PM
gholian
Jul 17, 2003 08:11 AM
