Check engine light wiring?
Old Mar 28, 2020 | 09:20 PM
Benny Meraz's Avatar
Hello everyone!
im im pretty much done with the wiring for the solo harness but the check engine light doesnt come on when i turn the key. I wired it to the brown/white wire. Is this correct or is there another wire im supposed to use instead?
Old Apr 14, 2020 | 01:02 AM
BrianI's Avatar
Re: Check engine light wiring?
I used socket C in the C207 for my 1988 Firebird. I would confirm the correct socket for your year vehicle and the pin out from whatever ECM you're using.
Did the light work before the swap?
Old Apr 14, 2020 | 09:47 AM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
I had to bypass the cel driver module. I just connected output from my ecm to yellow wire at cel driver. Basically just bypassing the driver module.
Old Apr 22, 2020 | 09:31 AM
Pocket's Avatar
Car: 91 Trans Am
Pin C on the C207 is the ground side of the MIL for all 3rd gens
Old Apr 22, 2020 | 11:02 AM
BrianI's Avatar
Pocket,
Just wanted to say thanks!! I used your wire harness guide when I did my LS swap. Would have been impossible without it!!
Old Apr 29, 2020 | 10:15 AM
Pocket's Avatar
Car: 91 Trans Am
Very welcome
Old Apr 29, 2020 | 04:11 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Word of caution I put LED bulbs in the cluster and for the CEL light you get a very subtle glow from the LED even with no trigger from the PCM. May not happen with all LED bulbs but it doesn't happen with the factory style incandescent bulbs. But it seems there is just enough grounding potential somewhere to get a slight glow. That was the only bulb that did it and its a straight wire to the PCM.
NeNick95
Nov 13, 2011 07:41 PM
onebad82z
Apr 30, 2005 09:45 PM
CHVYPWR
Mar 25, 2004 06:01 PM
Larry Dunlap
Jan 8, 2002 09:45 PM
