drive by wire to drive by cable for lh6 5.3
Old May 18, 2021 | 11:52 PM
colbybrooks99's Avatar
Car: 1986 trans am
Engine: 305 tpi
okay so i’m very new to this engine swap stuff so don’t bash me but i bought a 2005 denali with an lh6 in it for $300, i plan on swapping it in my 86 trans am with my 700r4. this engine has dbw and i was looking at converting to dbc for the sheet metal intake and my kick down for the trans but i don’t know if my ecm is compatible i’m pretty sure i have the e40 ecm. i was doing some research and it seems hit or miss if the ecm has iac or not, any help would be appreciated.
Old Nov 3, 2021 | 01:39 PM
MacRocZ's Avatar
Car: 1989 IROCz T-top & 1988 Convertible
Engine: 350 TPI x2
Axle/Gears: 3.73/4.11
Re: drive by wire to drive by cable for lh6 5.3
Check out LT1Swap.com
There's a whole section about PCM compatibility AND how to wire in TPS and IAC for this.
The TV cable will be the biggest problem. i will post more info on here once i have mine completed.
Old Nov 12, 2021 | 11:45 AM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
Can't do it. LH6 is a Gen IV engine, and was never offered with cable throttle.
The only way would be to swap cranks or reluctor, and change to a Gen III PCM.
Duane's 91 Z/28
Sep 10, 2011 11:27 AM
sloatgnc
Sep 27, 2010 04:15 PM
Bobby_80s
Apr 4, 2007 01:08 PM
LoudmouthSS
Feb 18, 2007 08:28 PM
