This fuel pump won't work?
Old Jul 20, 2023 | 04:58 PM
Nutro's Avatar
I bought the correct fuel level sender to convert a 3rd gen over to the 4th gen tank but this pump assembly does not allow that AC Delco sender to attach. This pump is AC Delco MU1730. I'm confused
Old Jul 22, 2023 | 08:56 PM
Nutro's Avatar
Re: This fuel pump won't work?
Anyone?
Old Jul 23, 2023 | 10:10 PM
2knight's Avatar
Car: 1982 Trans Am
Engine: 5.7 ls1
Transmission: 4l60e
I dont believe it will. When I did mine the "best brands" were that style and wouldn't work imo so I bought the cheaper brand that was setup for the proper style resistor chip.
Old Jul 29, 2023 | 09:08 AM
Grant2k's Avatar
Car: 1992 RS
Engine: Iron 5.7 LS
Axle/Gears: 4th gen rear, 3:42s, Torsen
I found that not all aftermarket parts use a factory style design. They're compatible if you're just replacing a factory unit as an assembly, but once you start trying to take them apart and swap parts from various brands it gets dicey as to what will work together.
Old Aug 8, 2023 | 04:04 PM
Nutro's Avatar
Anyone know if this pump assembly will work with the 0-90 sender?
Old Aug 9, 2023 | 03:18 PM
alan91z28's Avatar
COTM Editor
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
yes you will be able to make it work with that pump assembly... you might need to do some slight modifications, you can look at various posts by myself and others on this, but you will be able to make it work
Old Oct 13, 2023 | 07:36 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
GM updated the design and many of the parts makers followed suit. Unfortunately the best bet is to buy a used OEM one and put a new pump in it so you can put the 0-90 sender in it
MORREALE5
Sep 20, 2021 06:23 PM
killswitch_313
Dec 5, 2014 11:06 PM
91 zeee
Feb 13, 2014 01:37 PM
92RS4US
Jun 6, 2013 06:18 AM
RS-Chevy-SS
Oct 8, 2007 01:28 PM
