adding phoenix graphix stripes :)
Old Aug 8, 2013 | 12:16 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
I'll let the photos speak for themselves.
Attached Thumbnails adding phoenix graphix stripes :)-483937_10201750804994763_332396263_n.jpg   adding phoenix graphix stripes :)-1148894_10201750803994738_1240485799_n.jpg   adding phoenix graphix stripes :)-554938_10201750803674730_1888494767_n.jpg
Old Aug 8, 2013 | 09:27 AM
1Aauto's Avatar
Former Sponsor
Re: adding phoenix graphix stripes :)
Nice job on the striping! I love that color too.
Tony
Old Aug 8, 2013 | 01:16 PM
Chefobrien's Avatar
Nice! I just ordered my set of stripes from PG. How difficult or easy was this? Did you use their application bottle? I'm debating to do mine myself or let a shop do it.
Old Aug 8, 2013 | 01:53 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
this is the second set I have done my 91 I did about 6 months ago and it was tougher only because I used so much application gel. it took 24 hrs to be able to pull off the clear covering. this time I used less and it honestly took about 10 minutes to do the rear. but haven't pulled the clear off yet.
Old Aug 8, 2013 | 01:54 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
never realized how wide my tires look cool
Old Aug 8, 2013 | 02:13 PM
Chefobrien's Avatar
what is the silver lettering in the black stripes?
Old Aug 8, 2013 | 02:14 PM
Chefobrien's Avatar
also did you buy the molded stripes?
Old Aug 8, 2013 | 02:17 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
that's the clear covering has guides to tell you where to put the graphic once I peel off the clear those come off too. yes the pre moulded stripes in both cases. the 91 and the 86 . use there application gel it makes the job 100 times easier. little insite on it tho alittle goes a long way. I used to much when I did the 91 and it took 2 days before I could peal the clear covering off. this time I run a small bead down the middle of the strip and spread it with a clean finger then put it on the car and squeegee it out . the attached photos are of the 91 getting the kit .
Old Aug 8, 2013 | 02:24 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Those stripes look great. Nice job!
Old Aug 8, 2013 | 02:52 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Thank you hopefully I can get to work on it some more tonight . I had a server go down last night so I was up late working on the server and while waiting for it to rebuild the mail store I went and put on the rear graphics
Old Aug 8, 2013 | 05:09 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
jhainer,what do you mean by "molded"??
Old Aug 8, 2013 | 05:16 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
it's there premium kit which is moulded the standard kit comes with a roll of the stripes and you have to try to mould them around the corners the preminum kit comes pre moulded so the curve is built into the vinyl so it wraps the corner without bunching up. If you look at the pic I posted earlier it shows whe stripes sitting on my roof you can see some of the stripes are curved that's so that it will curve the corners easier.
Old Aug 8, 2013 | 05:26 PM
mantaguy's Avatar
Engine: 5.0 EFI
That's the reason I'm having a shop do my lower stripe,I herd it was tricky going around the corners.P.G don't offer that kit for TAs,(I think) I'll have to call them.
Thanks.
Old Aug 8, 2013 | 07:39 PM
mantaguy's Avatar
Engine: 5.0 EFI
Buy the way,your car looks great.
Old Aug 8, 2013 | 08:59 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
here's some more progress.
Attached Thumbnails adding phoenix graphix stripes :)-21468_10201757181834180_1057125750_n.jpg   adding phoenix graphix stripes :)-547466_10201757183394219_908793544_n.jpg   adding phoenix graphix stripes :)-1146552_10201757183154213_807363560_n.jpg
Old Aug 9, 2013 | 08:34 AM
Chefobrien's Avatar
Nice work, I just got my shipping info from PG, I'll see if I can get some work in & pics going next wknd
Ed1LE
Sep 30, 2018 09:14 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
z28venezuela
Oct 24, 2015 08:15 PM
gord327
Oct 3, 2015 01:25 PM
Gordonr1973
Sep 29, 2015 11:59 AM
