1989 IROC
Car: 1989 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.27 Posi
1989 IROC
Hey guys! A week ago I became the proud owner of a third gen IROC. This is my first project car, and the first performance vehicle I've owned. My experience is limited to doing minor maintenance, so I hope to learn quite a bit. The vehicle is in relatively good shape, drove it 150 miles home. Has new distributor setup, new injectors, B&M Shift kit. Also came with a super fugly cowl hood, which I plan to promptly swap back to the original.
As I'm a novice, I've been pouring through the forums trying to see what people have found success with. I put together a end goal project plan based on the recommendations I found, but some of the threads are in excess of 8 years old. Any advice from the pros would be very appreciated!
Here are the components I would like to utilize:
Will the selected components work well together? Should I go for cheaper variants? Are these choices overly ambitious for a novice? Let me know what you think!
- Holly Stealth Ram intake
- Holly Fuel Rail
- Dyno Dan 1 3/4" shorty headers
- Magnaflow 3" exhaust & high flow cat
- Holly 52mm throttle body
- Hotchkis Sport Suspension TVS
- Koni front and rear
- Circle D 3000 stall converter
- Swap the rear axle for 3.43? I was told it has 3.27 which is probably sufficient but I wasn't able to find the stamp to be able to tell.
- Paint also needs some work
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Re: 1989 IROC
Gratz on the new ride. Welcome to TGO. That's the fugly hood I'm looking for. I'd buy it, problem is it would have to be shipped to UT. If it's in good condition, maybe I could offset the cost of a stock hood. No trade from me, mine has a wrinkled spot.
Car: 1989 IROC-Z
Engine: 5.7L TPI
Re: 1989 IROC
I actually picked up the stock hood from the previous owner this evening! The cowl hood looks to be a home fabrication, I'll take some more pictures tomorrow so you can see what I mean.
Car: 1989 Formula
Engine: 355ci HSR SBC
Re: 1989 IROC
Heads and cam for that hsr.
Afr1040, trick flow, or profiler 195cc heads 64cc chambers.
Beehive springs, ultra pro mag rockers
268xfi or 280xfi cam
A good, good tune.
HSR will breathe to 6500rpm or so. If you keep the bottom end stock, go with the 268xfi cam. Shift around 5800-6000rpm.
If you build the bottom, 280xfi cam and shift at 6500.
All this because your heads are the problem and that cam is tiny.
That stall is a bit big for a stock cam.
HSR will give some gain on that L98 at the higher RPM, but you'll likely lose some down low without heads and cam.
You'll need injectors too. 27-32lb depending on application.
Might as well throw in a walbro 255l fuel pump too.
OR------
Port the tpi intake get a 2400-2600 stall, and get your headers. You'll need a tune regardless.
There are more than a few folks here doing the stealth ram thing here. SEARCH stock L98 with Stealth Ram and 268xfi and 280xfi cams.
It really depends on what you want out of your car. Street, drag, autocross or just a bit more oomph to the sock feel. Once you figure out the application, you can pick parts that work well together.
A good, good tune.
OR------
Car: 85 iroc, 96 z28 ss, 03 Silverado
Engine: 305, lt4, lingenfelter ls2
Axle/Gears: 3.08, 3.73, 4.10
Re: 1989 IROC
The hood looks to be the Daytona aftermarket hood. You should have no problem selling it or trading it.
Car: 1989 IROC-Z
Engine: 5.7L TPI
Re: 1989 IROC
Here are some snaps of the underside of the hood. I'm not an expert so input would be great, but it seems home brew.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: 1989 IROC
That's the Daytona hood. I have one,not a home brew. The side vents are shipped solid and can be cut out as the previous owner did.
First order of business is fixing all of the rusted areas before the rust makes the metal too thin. I would say go for a total repaint in a blue shade.
Car: 1989 IROC-Z
Engine: 5.7L TPI
Re: 1989 IROC
I forgot to thank you for the great suggestions truckerz. And thank you Eruk and Tibo for the clarification!
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: 1989 IROC
Welcome to the site......
The first recommendation I have would be to buy on line an official GM manual specific to your car.
You can find them used on EBay for $50.00 or so depending on the condition.
At the very least a Chilton's Manual on the car at your local Auto parts store for around $25.00.
This is definitely a "must have' item.
They are a great "bed time" reading option also.......
Car: 1989 IROC-Z
Engine: 5.7L TPI
Re: 1989 IROC
Thanks for the suggestion Ron! The gentleman I purchased it from was kind enough to include his manuals. I do find them helpful but at times they assume a base knowledge level that I just don't have... yet! With a little help from YouTube I'm slowly learning all the engineering concepts behind the parts.
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: 1989 IROC
Originally Posted by Evanslooten;6009237 some of the threads are in excess of 8 years old.
[LIST
[LIST
[*]Swap the rear axle for 3.43? I was told it has 3.27 which is probably sufficient but I wasn't able to find the stamp to be able to tell.[/LIST]
The rear axle lube is probably way overdue for changed, it's $10 for 2 quarts of new lube plus $5 for a new gasket, don't use RTV. While the cover is off, then you find the gear ratio stamped on the ring gear.
SUPER CHEVY66
22
Mar 6, 2016 01:29 PM
82z28man
LSX and LTX Parts
Jan 24, 2016 07:15 PM
'91CamaroRS
Jan 22, 2016 11:48 AM
82z28man
Jan 16, 2016 12:57 PM
