My 1987 Trans Am Gta
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
december 20th i bought myself a christmas present. 87 trans am gta 350 tpi tan interior white exterior, 79000 miles. Needs quite a bit of work but isnt in that bad of shape.
Car: '18 Jeep Wrangler, '19 Honda Accord
Engine: 2.0T in both
Transmission: 8 speed auto, 10 speed auto.
Re: My 1987 Trans Am Gta
What an awesome Christmas present!!! Btw the car looks really nice!!
Car: 92 B4C 1LE/2010 GT/2003 P71/2002 Z2
Engine: 5.7/4.6/4.6/5/7
Transmission: A4/A5/A4/A4
Axle/Gears: 3:23/3:73/3:23/3:73
Looks super nice to me! What work does it need? Congrats on the purchase.
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Nice! What are your plans with it?
BTW I'm sure you noticed the front and rear wheels are mounted in the wrong configuration.
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
No didn't notice it has 225 series tires on there which I kno are wrong. Car looks much worse in person needs new paint no rust or damage. Runs rough has a code 44 didn't run when I got it put a fuel pump on it to get it running. I think it sat for awhile. Center console and most trim pieces are broke. Needs new brakes and steering components. My plans are to restore the interior and exterior to its original glory. And would like to maybe swap on a l31 with tpi. Somebody replaced the stock motor with a early flat tappet motor with a melling mtc1 cam I think that is why it surges at idle
1 Post
Car: 1992 Trans Am
Engine: 5.0 TPI
Beautiful car! December 20th must have been the day to buy yourself a third gen. For me it was a birthday/Christmas present. Mine isn't a GTA but it's pretty rare all the same. 1992 Jamaica Yellow Trans Am. Good luck with your new car.
Man, what a good eye! I had to look at one of the pics again and sure enough, front and rear wheels are swapped. Actually the rims are marked on the inside as to where they go.
A very nice GTA, by the way.
Congratulations!
1 Post
Car: 91 Trans am
I'v always found it a little odd that GM was not able to build this cars keeping the same Offset for the front and rear wheels. I once thought of using the front wheels on all 4 corners, but when I tried them on the rear they were sticking out a little too much, making it look goofy.
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Nope sold the iroc got a 94 z28 sold that got a 01 z28 and sold that since I last was active on here
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
Looks better then mine when I first got it. Good luck and good purchace.
I believe that's the first time I've ever seen "headless" seats. LOL Nice car and best wishes on the restoration. Was this a Northern Virginia car??
-Chris
-Chris
Possibly, but the thing that gave it away for me, being a native of Northern Virginia, was the inspection sticker. They are big sticklers about that in that area, and would pop you as quick as they could if it expired, believe me.
-Chris
-Chris
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
bring it by one night this week or next, i get off at 6:30 all this week, but my normal time off is 4:30
you can check out the run down TA the neighbor bought and is planning on restoring, im sure if he sees yours he will be running out of his house to see it lol
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Yes the wheels are mounted "wrong" but I think we all can agree that it looks better when they are swapped. I did the same thing years ago & used some iron drum slip-on factory spacers I had laying around so that the rear wheels would fit on the front & clear the calipers.
Not the best pic but clearest I could find to show the wheel depths.
1 Post
Car: 91 Trans am
The camaro with the yellow crosslace wheels on the picture you attached, appears to have them in the "correct" configuration, but I am shure you could have found a better picture of a GTA, for exemple
Car: GTA
4 fronts look nice on these models. The drum spacer is only around 3.5 mm thick and the rear wheels on the front still look funny, even with the spacer.
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
It was my late wife's car & now our daughter has it. And the pic above is with the 12 year old paint job. It has been very well cared for & the purple/yellow combination was my late wife's decision. I think it is an awesome car, even though it still needs more power. But in the hands of the kids, the power level it has is perfect for them.
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
Went junkyard hunting found both headrest, sail panel covers, and sun visors.
The_Phoenix
02-04-2016 07:10 AM
beachrodder
08-25-2015 08:05 AM
TA8487
Interior Parts Wanted
08-23-2015 01:34 PM
