My 91 Firebird
Old Jun 1, 2014 | 08:47 PM
closed's Avatar
My 91 Firebird
Picked this up a few weeks ago dropped a new engine in, trans, wheels and tires made out really good on this one. car has 85k original miles and is a california car.
Old Jun 4, 2014 | 08:50 AM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Re: My 91 Firebird
nice score. thirdgens are getting harder to find for a decent price
Old Jun 4, 2014 | 10:26 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: My 91 Firebird
Nice find.
Old Jun 4, 2014 | 04:45 PM
closed's Avatar
Re: My 91 Firebird
I actually traded that roughed up 85 z28 in the background for it. The z28 was a dependable car with nice body in all primer but interior was shot and ttop's leaked back with a cracked windshield. The bird had a bad trans engine was knocking and exhaust was a cobled up mess plus had junk tires. I had already built an engine to drop in the camaro, picked up a good 700r4 for $100, built new exhaust for it and picked up those wheels and tires new for dirt cheap. I think I made out alright on it. 2 weeks later it went from a barely running car to a good dependable driver with sealed ttops nice interior and nice exterior. I am one happy camper.
Old Jun 8, 2014 | 11:03 AM
closed's Avatar
Re: My 91 Firebird
thanks to a bad spot in the road my crappy exhaust got destroyed so spent all day yesterday building dual exhaust with dynomax bullets.
Old Jun 11, 2014 | 11:58 PM
closed's Avatar
Re: My 91 Firebird
Found the OEM radio in the back hatch locked compartment and it works so I made a much needed modification and works perfect with my iphone now
need a new radio faceplate surround mines cracked
Old Jun 14, 2014 | 09:28 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Re: My 91 Firebird
Faceplates are pretty cheap, like 30 bucks or so on ebay AFAIK
Are those C&C T-tops I see? !!!!
good looking car
Old Jun 20, 2014 | 11:19 AM
closed's Avatar
Re: My 91 Firebird
Ya i plan to pick up a faceplate its on my list of little parts and yes sir those are C&C T-tops i need to pick up another set it would be nice to have a spare set for that one sad day something happens. I also need the plastic cover on the passenger side on its there but broke in half could probably repair.
Old Jun 23, 2014 | 10:36 PM
MintWS6FORMULA's Avatar
From: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
Re: My 91 Firebird
What's that in the radio? An aux jack? I had an early '91 , same radio and mine never had that.
Old Jun 24, 2014 | 07:01 AM
alex722607's Avatar
Re: My 91 Firebird
The modification is the aux input.
Old Jun 24, 2014 | 07:17 AM
closed's Avatar
Re: My 91 Firebird
Yes I added in the aux input made it pretty nice im happy with it. Still need to clean it up some.
Old Jun 24, 2014 | 07:39 AM
alex722607's Avatar
Re: My 91 Firebird
The mod is well worth it, I hid my input on the same panel as the switches for the hatch and defrost, in my case I put it next to the ash tray light that is there on the 85-90 models. ( not sure about 91-92)
Old Jun 24, 2014 | 09:37 AM
closed's Avatar
Re: My 91 Firebird
I thought about moving it outside of the radio but figured if I needed bluetooth later in the future I could remove it without having a extra hole floating around somewhere.
Old Jul 6, 2014 | 01:12 PM
closed's Avatar
Re: My 91 Firebird
This one is from the drag strip a couple weeks ago
These are from the 4th of july car show
Old Jul 7, 2014 | 07:42 PM
DynoDave43's Avatar
Re: My 91 Firebird
How did it do at the track?
Old Jul 7, 2014 | 07:56 PM
closed's Avatar
Re: My 91 Firebird
To be honest like straight up **** best was a 15.9 @ 93mph was acting like it was running out of gas major bog off the line then bog again at 1 - 2 shift. I plan to recurve the timing to get it in right then goto the carb its a little edelbrock 1405 600cfm carb. fuel pressure is solid. I did drop the tank and found that PO pulled the electric pump out without extending the pickup so that is now extended im sure that may have contributed to my bog big time. Dropping the tank on these is no joke plus to top it off I was wondering why PO cut the steel fuel lines and reconnected with rubber hose needless to say i looked up and found out why. I am one to do things the right way and sucks to find someone has already hacked at the sheet metal at least they didnt cut the carpet and looks like they prepped and primed the cuts good then riveted in new metal but really wish id had the time to weld that back up but show was coming and wanted a plaque for the bird. I did find all new suspension while i was under there.
64goatman
Sep 9, 2015 01:09 PM
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
