Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
Cam Swap Process Pics , The Motor looks different than it Did last Sat.
Old Jul 30, 2002 | 09:01 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Just thought I would share my cam swap photos with you guys so far. Should be done hopefully Friday nite.
Attached Thumbnails Cam Swap Process Pics , The Motor looks different than it Did last Sat.-camswap-001.jpg
Old Jul 30, 2002 | 09:04 PM
Car: 99 Formula
Axle/Gears: 342
Power just waitin to be installed. Roller Rockers will be here Friday.
Attached Thumbnails Cam Swap Process Pics , The Motor looks different than it Did last Sat.-camswap-004.jpg
Old Jul 30, 2002 | 09:09 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Ahhhh... i can hear it now....
Krum krum krum krum krum krum krum krum krum VR00000000000MMMMmmmmmm.... rum krum krum krum krum krum krum krum krum....
:tires squeal: you can almost smell the burnt rubber already
:lala: :lala: :lala:
Old Jul 30, 2002 | 09:22 PM
Car: 99 Formula
Axle/Gears: 342
That and the roar of my Hooker. Oh yeah, and the whine of the quiet gear drive.
Old Jul 30, 2002 | 09:33 PM
Twistopher's Avatar
Car: 91 Z28 Convertible
Engine: 305TPI
no is that anyway to refer to your girlfriend
Old Jul 30, 2002 | 09:35 PM
Car: 99 Formula
Axle/Gears: 342
Yeah right, after this project I couldn't afford head work from a Hooker.
Old Jul 31, 2002 | 07:29 AM
BikertrashDude's Avatar
oohhhh,,,,,,ahhhhhh
power :hail: :hail: :hail:
cam:hail: :hail:
when finally tear into my NEW engine i plan on doing
the whole exaust at once headers on back
then i say 6 months ($$$) later
heads and cam together.
looks good mark keep us posted
biker
Old Jul 31, 2002 | 08:05 AM
MdFormula350's Avatar
looking good Mark, whats the specs on the cam?
Old Jul 31, 2002 | 08:27 PM
Car: 99 Formula
Axle/Gears: 342
The old cam was a 390/410 lift.
The Comp 268XE is a 477/480
224/230 duration at .050
110 lobe separation.
Old Jul 31, 2002 | 09:00 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
what was the hardest part of the swap?
Old Jul 31, 2002 | 09:04 PM
oh yeah, stupid question
what is this thing?
Attached Thumbnails Cam Swap Process Pics , The Motor looks different than it Did last Sat.-whatsthis.jpg
Old Jul 31, 2002 | 09:05 PM
Car: 99 Formula
Axle/Gears: 342
Well, it's time consuming for sure.
The one think I had my brother do for sure was slide out the old cam, I didn't want to risk damaging a bearing.
Adjusting the rockers is the last hard step. My brother doesn't like to do it anymore since he did it once and bent some pushrods.
Old Jul 31, 2002 | 09:07 PM
Car: 99 Formula
Axle/Gears: 342
what is this thing?
Oil Sending unit or Oil Pressure sending unit, something like that.
Old Aug 1, 2002 | 11:30 AM
thats what i thought...........................
Old Aug 1, 2002 | 07:05 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
Pretty Damn sweet i think thats what my TBI 305 needs is a nice little roller cam HEHEHEHE
Attached Thumbnails Cam Swap Process Pics , The Motor looks different than it Did last Sat.-camaro.jpg
Old Aug 1, 2002 | 08:43 PM
RS92's Avatar
I wish I had know you were doing this now I would have came over and heckled you some, or at least drank a few beers watching you guys work
Old Aug 1, 2002 | 08:54 PM
Car: 99 Formula
Axle/Gears: 342
We're not done yet. Still have to get the gear drive and roller rockers, hopefully I'll have both tomorrow.
Old Aug 4, 2002 | 09:00 AM
Car: 99 Formula
Axle/Gears: 342
Update, still have some stuff to finish, and I have to go to work.
Attached Thumbnails Cam Swap Process Pics , The Motor looks different than it Did last Sat.-camswap2-001.jpg
Old Aug 4, 2002 | 10:41 PM
Nasty_Bird_'90's Avatar
Hey Mark, looks good man. I especially like the soda can in front of the blower motor ! When are you gonna clean up that engine bay man? You know, neaten up the wiring and such. It's a disgrace my friend.
Old Aug 4, 2002 | 11:02 PM
Car: 99 Formula
Axle/Gears: 342
That's actually my brother's beer can. The wires will get cleaned up when I get around to puttin in that heater box fabrication. It'll be before the show.
Old Aug 5, 2002 | 04:50 AM
poorboy8's Avatar
Car: 79 Camaro RS
Engine: 355, carb, alum heads, XE262
Transmission: TH350
Looks good man, hopefully you'll get out of the 15s :sillylol:
Old Aug 5, 2002 | 02:08 PM
86_iroc-z28-350's Avatar
I AM IN THE PROCESS OF A HEAD SWAP, PUTTING ON A SET OF GOOD 305 HEADS TO BOOST MY COMPRESSION THE CHEAP WAY. Should have it together tuesday Also i did the cam swap about 2700 miles ago and u will notice quite a difference, I will post some pics of my engine all tore down when i get a chance.
Old Aug 6, 2002 | 07:59 PM
Car: 99 Formula
Axle/Gears: 342
https://www.thirdgen.org/techbb2/sho...hreadid=124170
Here's the finished product.
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
