For the local computer guys.... help
Car: 99 Formula
Axle/Gears: 342
Not sure if you can, but check this thread. The shop couldn't fix it, so I guess I'm chit out of luck.
https://www.thirdgen.org/techbb2/sho...hreadid=131321
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Mark,
Too bad you don't live a little closer. Bring your "dead drive" to the next gathering. I've got a hot dog that says it is recoverable.
:sillylol:
(Erik = Information systems manager, 6+ years on the job...)
:sillylol: (Erik = Information systems manager, 6+ years on the job...)
Car: 99 Formula
Axle/Gears: 342
You really think the info is recoverable. The guy said it's just not getting any power to it, not spinning or anything. I had to take the laptop back, it wouldn't start up after they installed more RAM for me, he said he got the net to work on it though. Had to wipe out the C drive though.
Engine: 5.7L TPI
Axle/Gears: 3.42:1
What would not start after the RAM install? Dunno what someone can screw up with poping a door and snapping in a SODIMM... Thread Starter
Car: 99 Formula
Axle/Gears: 342
Originally posted by ES87iroc
WTF? Your O/S load was semi-fubar, but not beyond help from what you were saying.
What would not start after the RAM install? Dunno what someone can screw up with poping a door and snapping in a SODIMM... Supreme Member
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Engine: 5.7L TPI
Axle/Gears: 3.42:1
The computer would get power for like 2 seconds and there would be noise, but then nothing. They're goin to call HP and see what's up. The guy said he got rid of all 131 viruses, but the net still wasn't working. He said if I was using Win 2000 he could have saved the C drive, but he wasnt sure about XP, I didn't really have much important stuff on the C drive, so I'm not to mad about that.
131 viruses!?! Yikes! I would have flattened that mess too then if it were me. Trouble is, what is lurking around on that other drive. Guess I will quarentine it from the rest of my home network when I get a look at it.
Ewww...I would think that the memory module is not compatable with the laptop from what you are discribing. Some laptops require specific modules designed for them, it's kinda like a guarunteed future parts sale for the manufacturer.
Car: 99 Formula
Axle/Gears: 342
Umm, did you tell him that win xp is just a revision of win2k when you boil it down?
Ewww...
Car: 99 Formula
Axle/Gears: 342
One more comment. This guy said that the HD could be opened up to see if the discs got misaligned?? think it could be?
also, could I send it back to the manufacturer and have them get the old info off of it onto another one.
Engine: 5.7L TPI
Axle/Gears: 3.42:1
One has -nothing- to do with the other, it sounds like he is just trying to babble his way out of not knowing what the problem is. Again, keep it away from him if you can.
You can ship it to me in the mean time if you want, and I will let you know what turns up. As far as the manufacturer, per your warranty, they are -only- responsible for supplying you with another drive if they see fit, and have no interest or responsibility for your data.
Let me know the scoup when you get a chance... Thread Starter
Car: 99 Formula
Axle/Gears: 342
Let me clear up some confusion, the " guy" that said they discs may be misaligned, was a guy in one of my classes, not the guy from the computer shop.
Engine: 5.7L TPI
Axle/Gears: 3.42:1
However, if you told him that your drive had no power, he is full o'
, one has nothing to do with the other.By severe shock I mean in excess of 4 g's...
Car: 99 Formula
Axle/Gears: 342
Ahh, gotcha.
Ahh, gotcha.
My GF kind of bobbled it the other day right before it quit, but nothing worse than what happened last semester.
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
, friendly female bashing!
