Mid-Atlantic Region Regional board for all of the Mid-Atlantic states. Discuss gatherings and get togethers.
Hang Out at the Drag Strip
Old Nov 9, 2006 | 09:53 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
Hey guys longtime no see well im finally making some progress on my RS and my 305 build up. I finally got the heads back from the machine shop and they look great. Still waiting on my new radiator and some gaskets and she will be running again,then the hood needs to be painted cause i took it off a 86 IROC so its a red hood on a green car But anyways i was gonna see if anyone planned on going to Capital or budds anytime soon??
Old Nov 10, 2006 | 10:18 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
im trying to go the last weekend there open at mir (budds) hoping for 13's beat a turbo talon with rebuilt engine and 18psi.
Old Nov 11, 2006 | 04:47 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
whens the last tim ethere open at budds would like to just go and watch we should get out there im moving in dec so last time i get a chance to meet some of you guys
Old Nov 11, 2006 | 10:59 AM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
I went to Capitol last night was a bad night, ran .3ths off what i normally run. The car was set up just the same to. Fustrating. I am sure I will make it back before the winter is over, I hope it turns out better. Anyway I am up for a track hangout sounds fun.
hey denis91rs not to rain on your parade but there is a lot of 12 sec 305 out there. go to the drag racing forums and check out waltercraft race cars post (i think that is it anyway). or look up mw66nova hes got some pretty impressive times. low 12's on a 305. but i hope you can get it there that would be very cool, good luck. hope to see that run one day also.
Old Nov 12, 2006 | 02:20 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
hey yeah, there are tons of 10, 11, and 12 second n/a 305 powered fbody stock eliminators, and i've been 12.31@108mph with my daily driven n/a 305 powered f-body...
Old Nov 12, 2006 | 11:18 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
Damn thats fast is the a stock bore 305 or is it a stroker or what im still on a standard bore with stock pistons and rods everything on top means business though.
i might jump up to a bigger cam now that i got my heads worked
im lookin at a .497/.503 its a .452/.465 now
Old Nov 12, 2006 | 11:50 PM
mw66nova's Avatar
Engine: 7.0L
it's .030 over and has an eagle cast crank, ohio crankshaft forged rods and a set of hyperuetectic stock replacement pistons, but it's still the standard stroke. i suppose "technically" it's a 310, but 5 cubes and forged rods ain't putting me out in front of everyone else, i can promise you that.
don't focus on lift as lift doesn't make the horsepower. duration makes horsepower. you'll want something in the 230* @ .050 range. mine is an old magnum 280H cam. 230*/230* @ .050", .480"/.480" 110lsa.
your cylinder heads are gonna hold you back though. what are you doing for converter and gears? what kinda weight mods have you done? how bout suspension and tires? what are you running there?
Old Nov 13, 2006 | 12:31 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
its got a 700R4 original tranny from 91. It was redone like 3 years ago with a 3500 B&M stall,and a B&M Trans Pak
the rear is the stock housing with Moser 28 spline,3.42 richmond gears and the auburn pro series unit
the heads were the stock L03 castings and i had them worked to the high heaven
intake valves are 1.94 and 1.60 on the exhaust and its all stainless valves,7 degree springs,and full port/polish only thing im worried about with the heads is the compression because we grinded the chambers out
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
JSDaddy189
Sep 26, 2015 03:50 PM
