Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
91 Camaro may return
Old Jun 1, 2004 | 09:26 PM
fakezcar's Avatar
I may have a chance at my old 'Maro back. If I do this is the planned motor work/Tranny Combo. Let me know what 'ya think.
Block--6.0L Iron LS1
Heads--MTI Stage III+ (gotta flow ALOT)
Cam--Custom Comp Grind
Pistons--Forged
Rods--Forged H-Beam
Crank--Forged Offest Ground for the ever so slight Stroker
Dry Sump Oiling
Custom Headers feeding two (2), yes two, 105mm Turbos...most likely turbonetics.
Comp Cams LSX intake with 90mm TB.
Tranny---TH-400 with a custom machined adaptor for the LS1...or a Richmond 6-Speed.
Rearend will be a Strange 12 Bolt geared according to the Tranny.
Oh, Slicks are going to measure 28x12x15.
I guess I gotta Mini-Tub it.
Motor will be controlld by the F.A.S.T. Engine Management Set-Up.
What do you guys think se'll run down the 1/4 and what HP #'s would you expect to see at the tires?? I'm not looking for your opinions on what I'm doing just want some reaction, and how you think this set-up will work. Oh, Car.
91 RS Camaro
Gonna be caged of course but still have a fully functioning interior, I know I'm crazy.
Chris
Old Jun 2, 2004 | 09:27 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Speed costs money, how fast do you want to spend?
Sounds like you'll have an easy $30k in the setup. I'd buy a used 2500 Suburban and a trailer, use 5k to redo the body + couple sets of wheels & tires, and then use the remaining 5k on the drivetrain and live with 11s.
That's just me though...
Old Jun 2, 2004 | 10:57 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
wish i had that kinda budget i could buy another third gen and redo my 66 impala ......lol...but if you really do do that to your ride man itll be a screamer for sure
Old Jun 2, 2004 | 11:49 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Well, it may run this good......
http://www.turbobuick.com/chris_chow_car.html
Old Jun 2, 2004 | 11:58 PM
THEGENERAL's Avatar
yeah when i finally get everything going over here id like to take a stab at building a twin turbo smallblock using one of these kits here http://www.twistdisc.com/id14.html
i think it looks awsome and could produce some mean numbers if built correctly
Old Jun 3, 2004 | 09:53 AM
fakezcar's Avatar
the whole idea behind going to an LS based motor is reliability and wow factor. Plus that's what we work on at the shop. Unfortunately we get more 4th than 3rd gens but oh well. I think it'll be a fun car that I can drive on the street with a full interior and *possibly* A/C. Should be fun though.
Old Jun 3, 2004 | 10:42 PM
sleeperZ28's Avatar
Car: 86 z28
Transmission: built 700R4
i think the idea is awesome. the 6.0 liter is a good base and they rev really good too which is good for a turbo. you could always try to find an aluminum 6.0 liter block and save some weight and add to the wow factor . i didnt know that a 6.0 liter could be converted to dry sump is it very much work?
Old Jun 9, 2004 | 03:16 PM
fakezcar's Avatar
i figure if I'm in it that far I might as well do it since it can only help. I plan on removing the high beam Lights so all you see are two little fans where the lights used to be. I think all that on a 10.5" Slick should be good enough to scare even the fastest guys in the area
Fronzizzle
Mar 18, 2019 08:29 PM
Grant2k
Jul 10, 2018 04:01 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
wayshegoes
Aug 17, 2015 12:00 PM
TEDSgrad
Mid-West Region
Aug 10, 2015 07:12 AM
