Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
Where to drop off an engine block?
Old May 6, 2005 | 01:45 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Ok, winter is over, so I need this engine block out of my trunk. Where should I take this thing to get rid of? Junkyard? Iron recycling place? Where?
Old May 6, 2005 | 04:49 PM
MNformula350's Avatar
you could take it to a junkyard. junk steel is like gold right now so I would find it hrad to think a junk yard would refuse it. if a junkyard wouldn't take it you could take it to a machine shop maybe, they would put it in thier scarp barrels. steel right now is going for roughly 80-100$ a ton and 4 chevy small blocks would be about 1 ton so if you have anymore steel than would ad up to alot of weight it would be worth taking it to a recycling ctr to get some money for it.
Old May 9, 2005 | 05:59 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
Hey Stekman,
You can take it to Louis Padnos Scrap Metal. I used to work there. Its off of the Ann st. exit off of 131 North. Get off there then take a right on ann and then a right off on to turner. They will even pay you for it. Not sure how much though lol.
Old May 11, 2005 | 11:15 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Originally posted by eXesiv|83ta
Hey Stekman,
I will give them a call tomorrow!! Thanks!
Old May 11, 2005 | 11:18 PM
ktacam's Avatar
Car: 85 z28
Engine: 305 tpi (I got screwed, supposed 350)
Transmission: 700r4, b&m shiftkit
You can drop it off in my front yard.
Old May 12, 2005 | 07:45 AM
Engine: 355 chevy
No Problem.
Old May 12, 2005 | 09:30 AM
notmuch's Avatar
Car: 69 Chevelle SS Lookin' for 92 Z ver
Engine: 468
Transmission: th350
Just for reference, a small block chev "block" weighs 166 pounds when new. By the way, that is the weight of a one piece rear seal block. It may vary by a few pounds one way or another with diffrent blocks.
Old May 14, 2005 | 03:21 PM
transam84's Avatar
well a sbc with all internals, heads, intake , water pump is close to 400lbs, basically you need a long block motor to get the most weight out of it. I was the guy that posted the junkyard reply under Dave84birds name. I was at his house last wkend and I didn't realize I was under his name when I posted it lol.the last time a buddy of mine and I went to drop off some motors for scrap we figured it would take 5 sbc to equal a ton and get roughly $75-$100 for it all. alot of places will make you drain all the fluids first so anyone planning on doing this make sure you drain the oil and coolant first.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
