Xtronics Pocket Programer
Old Dec 4, 2006 | 09:36 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Includes software, dos and windows versions. Also, update can be downloaded from Xtronics website. Has parallel cable to connect to computer. Asking $95, Paypal or bank check.
Old Dec 5, 2006 | 05:07 PM
simz28's Avatar
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
this is something i would like to get into as i make more mods to my car, but i am not very knowledgeable on the subject. Could you help me out with some info for ex. what i would need to burn my own chips. thanks
Old Dec 5, 2006 | 09:16 PM
Did you see my Ease scanner forsale?
https://www.thirdgen.org/forums/engi...obdi-scan.html
These are basicly the only two things I used to edit my ECM. Datalog using the EASE software. Make proper changes (see Traxion tuning hints search) using WINBIN, Tunercat or Tuner pro (Do a search. all free which links can be found on this site). Then use pocket programer to burn chip. Put chip in memcal adapter with memcal and install in ECM.
I have a memcal adapter and a spare 29C256 eeprom. With these that should be all the hardware you need to get started.
$340 will get you everything including memadapt and EEPROM.
What year is your car?
Old Dec 5, 2006 | 11:20 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Not to mention seeing the extensive tech article on this site that details what you need to get started burning your own chips for your car.
Old Dec 9, 2006 | 05:16 PM
ttt
Old Dec 22, 2006 | 12:50 PM
ttt
Old Dec 31, 2006 | 03:47 PM
ttt
Old Jan 10, 2007 | 08:01 PM
ttt
Old Feb 2, 2007 | 06:46 PM
ttt
Old Feb 3, 2007 | 03:14 PM
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
pm sent
Old Feb 6, 2007 | 08:08 PM
Sold
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
86IROC112
Nov 7, 2015 06:50 AM
randy210
Oct 15, 2015 03:43 PM
ULTM8Z
Oct 2, 2015 01:25 PM
anesthes
Sep 21, 2015 10:24 AM
