Need help identifying something
Car: 1956 Chevrolet 210
Engine: Chevy 305 V8
Transmission: TH350
Axle/Gears: Posi 3.42
I own a 84 z28 305 H.O. and I need help identifying a part located on the driver's side firewall. I have attached a picture with an arrow pointing to what I'm talking about.
What is this? What's it's function? Why does mine look like it's caved in? Does it have to do with vacuum?
I am asking this because I have had a few minor problems that I cannot figure out:
1. Lots of interior "pressure noise" when I adjust anything on the heater/ac controls
2. Check engine light ONLY while cruising at 60-75 mph...disappears once I get back to city driving (checked and got ECM code 44 - lean mixture condition)
3. No washer pump functioning for windshield wipers.
Any takers? All help is appreciated
Transmission: TH350
Re: Need help identifying something
To be honest, not sure because I'm not near the car tonight....stored at my dad's garage...i will have to get back to you on that.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
looks like a piece of rubber/foam just pushed in there. Might be nothing.
Transmission: TH350
Here are some more pics...again, what is this and what's it's function? The larger hose coming from the bottom leads to a port on the back of the intake manifold...the smaller cable above it leads across the firewall and back behind the condenser and blower motor. Please reread original post regarding small problems I am experiencing...does this have anything to do with them? Thanks again.
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Looks like some kind of EVAP canister, but I have never seen anything like that before.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
My 84 ho has the same thing! Will try and climb over the snowbank and
get into the barn and eyeball exactly what/where its for!
Its sleepin' for the winter.....................
Transmission: TH350
C'mon...surely someone out there knows what this is! I have searched images,diagrams, schematics online and cannot get any answer as to what this is and what it does, although it is present on a lot of 3rd gen engine compartment images online. I have also paged through the Haynes manual as well as the Chilton's manual with no luck.
Does anyone have a gm shop manual and could look it up? Any help will be much appreciated.
I don't want to really mess with it until I know what it is and what it does.
[It's location is just above the master cylinder and brake booster on the firewall...as mentioned before, the larger hose on the bottom leads to a port on the back of the intake manifold (vacuum?) and the smaller cable above the hose channels across the firewall to the passengers side and goes behind the a/c accumulator unit. It's usually not caved in either! Don't know why mine is....nothing touches it when the hood closes]
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
vacuum canister for the heater/ac controls.
later cars have a round one hidden under the fender near the nose.
if yours is leaking it can be bypassed by connecting the lines together.
Transmission: TH350
In reviewing my first post, could a leak be causing my problems listed? Also, why would it be caved in?
Car: 1988 iroc-z
the pressure noise at the heater control is a vacuum leak in the heater control.
the lean condition is most likely a vacuum leak,most likely a combination of the heater control,canister and a few hoses.
the washer pump is unrelated and most likely a bad pump,or hose.
the canister is a storage device for negative pressure,my guess is the plastic just gave out in the heat of the engine compartment.
Transmission: TH350
Thanks for the help regal301. Obviously, I'm new to being a camaro owner and I lucked into the Z28 that I own.
It's all original (pretty mint cond.) with only 27800 miles and I didn't want to mess with anything until I had an idea of what it was.
Linson
Sep 21, 2015 01:08 PM
