Ohio?
Old Aug 17, 2006 | 04:52 PM
  #501
fastfirebird's Avatar
Car: 91 Firebird Formula,2 1979 T/A's
Engine: 5.0 TPI, 403
Transmission: 700r4,turbo 350
Uniontown,Ohio here. I have a 91 Formula
Old Aug 30, 2006 | 10:57 PM
  #502
Firebird1984's Avatar
Car: 1984 Firebird S/E
Engine: 350 V8, 4 barrel carb
Transmission: 700 R4 automatic overdrive
I'm in Marion, about an hour north of Columbus and enjoying my 1984 Firebird.
Anyone else from up this way?
Brad
Old Aug 30, 2006 | 11:04 PM
  #503
1fastcamarosss1's Avatar
cleveland ohio, actually lakewood.
Old Aug 31, 2006 | 01:44 PM
  #504
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
Im from Mantua Ohio, if theres anyone that goes to the Solon car show on tuesdays and feels like talking about third gens let me know. Especially if its about prom tuning because im planning on getting into that soon, iv just been reading things for now though.
Old Aug 31, 2006 | 05:04 PM
  #505
CashMunson's Avatar
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
i've probably seen your car, i'm in ravenna, lived in aurora for 15 years also. you should come up to giant eagle/A&W here in ravenna on saturday nights. we have an informal gathering that starts about 9 pm. I might have some info that would be useful to you.
Old Sep 1, 2006 | 04:13 PM
  #506
Method_z28's Avatar
Car: 92 camaro z28
Euclid ohio here....just east of Cleveland
Old Sep 1, 2006 | 10:03 PM
  #507
91 Ragtop's Avatar
Car: 1991 Trans Am Convertible
Transmission: 5-Speed
Originally Posted by steves 92rsconv 03-26-2002, 10:17 PM
Hi, I'm a newly regestered member from Canal Winchester, Ohio ( near Columbus ). I have a 1992 RS Convertible that I bought back in Jan. of 1995 with 61,000 miles. It now has close to 190,000 miles on it and still runs GREAT!!
Damn.. The thread that won't ever die... Well I sold my Camaro back in 2004 with around 206,000 miles on it. I just bought a 1991 Trans Am Convertible last week. It has 156,000 miles on it and I hope it will make it to 200,000 also.
Still in Canal Winchester here....
Old Sep 3, 2006 | 12:43 PM
  #508
Engine: 305ci TPI
Ill try and make it out next weekend if possible. i probly wont risk driving the camaro on expired plates though, im having trouble passing e-check.
Old Sep 5, 2006 | 02:06 AM
  #509
CashMunson's Avatar
Engine: 408 LS
maybe you should check out LSRacingchips - Home for a good tune, they tuned my car and i passed with no smog equipment and a hollow cat converter. the guy that runs it is local and could probably tune your car around here. what trouble are you having with the echeck? did you fail once already?
Old Sep 5, 2006 | 07:42 AM
  #510
Engine: 305ci TPI
id rather not pay for a chip when i could eventually burn my own, but i would still look into it. and echeck is confusing me, i failed before, put a new cat and cat-back on, and failed by more! so either way i think i can pass just by proving that i spent a certian amount of money trying to pass.
Old Sep 5, 2006 | 07:59 AM
  #511
firebirdjones's Avatar
Wow, most of you seem to be way up north around Cleveland or Columbus. I am down near Cincinnati. We have a rather large cruise inn on Friday nights in Milford, around 500+ cars show up if the weather is nice. It's actually getting too large to suit me. We also have one on Saturday nights and Sunday nights, but those aren't as large and much easier to get a parking spot. There are even a couple cruises that go on during the week nights but those haven't interested me much. Larry.
Old Sep 7, 2006 | 11:58 PM
  #512
CashMunson's Avatar
Engine: 408 LS
what part of the test are you failing? look at your printout and tell me which part says fail. alot of times a failing o2 sensor will make you fail echeck. also another trick, try to go during the day to have the test done when there is the least amount of people. you want as few people as possible so you can get right in while your car is still warm, run the hell out of it and get everything nice and hot then take it in there. i've seen a few people pass simply by doing that.
Old Sep 8, 2006 | 12:12 AM
  #513
Ironmahn's Avatar
Car: 1986 Trans Am
Bucyrus... here.
Old Sep 8, 2006 | 01:12 AM
  #514
i put 4 bottles of 91% rubbing alcohol to my have a tank of gas,(thinned down the mix) and turned the timing don't a bit and passed. also ran on highway for 15 mins before. just an idea.
Old Sep 8, 2006 | 11:45 AM
  #515
Engine: 305ci TPI
I dont mean to turn this thread into emissions help, but thats for the input. ill be taking it to the test again today, i ran sea foam injector cleaner through it, and ill let it run longer than the 10 minutes it takes to get there, and ill prolly put in some 91% alcohol because a mechanic i know has told me the same thing.
only thing is, i failed the NOx only, and iv read those are caused by high combustion temps, and i thought alcohol burned hotter but maybe cleaner too. i also thought i might try higher octane gas, because higher is supposed to be harder to ignite, maybe burn slower, maybe burn cooler? retarding timing might help too but ill try to pass without doing that.
thanks again maybe ill be able to stop at the revenna car meet tomorrow if i pass today haha.
Old Sep 8, 2006 | 09:56 PM
  #516
CashMunson's Avatar
Engine: 408 LS
nox is usually o2 sensor or bad cat converter. let me know if you plan to head up there. here is the problem i see with the alcohol, the higher octane won't let all the fuel burn up. do you know what that does? it washes oil off your cylinder walls and allows the pistons to scar them. my grandpa did the same thing, but it was with some beater *** chevy blazer we didn't care about. he bought a bottle of absolute alcohol, it was 100% and poured the whole thing in the gas tank, yeah it passed... the engine was dead not 6 months later.
Old Sep 9, 2006 | 06:55 AM
  #517
Engine: 305ci TPI
that sounds very possible and a little scary, plus i was only planning on having 3 ors so gallonos in the tank at the time so that the alcohol wouldnt be much and wouldnt be in there long. the strange thing is the O2 has less than 500 miles on it and the cat is brand spankin new. when i put the new cat it failed by more! haha, so that just confuses me.
and i wont be able to take it to ravenna tonight due to a brake line failing and leaking, so i decided to re-do all the brake lines and such today and tomorrow.
thanks for the heads up on the possible alcohol side effect
Old Sep 11, 2006 | 08:50 AM
  #518
CashMunson's Avatar
Engine: 408 LS
how did the brake job go? did you get it fixed?
Old Sep 16, 2006 | 12:47 PM
  #519
cam92rs's Avatar
Car: 25th anniv. camaro
Engine: 305 tbi
live 60 miles east of columbus
after this winter,ya'll wanna get together somtime and have a carshow or somthing? i got a 92 rs teal l03 auto t-top.i live in a little town called New concord.i know of a guy thats got a 87 iroc,i know of a guy with a 92 rs, and i know of a guy with a 84 berl, with a 283 in her.but i havnt really talked to them yet,i need to tho.well,we should get a carshow goin!
Anthony
Old Sep 26, 2006 | 01:06 PM
  #520
CashMunson's Avatar
Engine: 408 LS
anybody want to meet up at the ravenna car gathering on saturday night? i'll be there with my GTA.
Old Sep 26, 2006 | 04:18 PM
  #521
cam92rs's Avatar
Engine: 305 tbi
wheres ravenna? is that by defiance?
Old Sep 26, 2006 | 04:33 PM
  #522
CashMunson's Avatar
Engine: 408 LS
go to maps.google.com and look up ravenna, ohio 44266
Old Sep 26, 2006 | 09:06 PM
  #523
cam92rs's Avatar
Engine: 305 tbi
ok,thats about 2 hours north of me.what time does it start? and end? idk if i could get my l03 maro to make it that far,lol,plus i got work,its this saturday? anymore coming up that i could request off work for?
Pride
Anthony
Old Sep 26, 2006 | 10:41 PM
  #524
CashMunson's Avatar
Engine: 408 LS
depends on the weather for how many people will show up. not sure if any of the people from the board will be there, but i'm sure alot of local people will be. it starts around 9 pm saturday night.
Old Oct 7, 2006 | 12:17 AM
  #525
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
Transmission: 4L60E 4000 Stall
Axle/Gears: 3.23 G80 (01 TA)
Im checkin in from the east side of Dayton. I currently got an 87 Firebird but it really blows. I had a 99 Z28 until I crashed it on E Fifth Street a while back. Looking for a Straight bodied 3d Gen.
Old Oct 8, 2006 | 07:26 AM
  #526
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
You should buy my turbo kit and make it move lol
Old Oct 18, 2006 | 09:03 PM
  #527
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
I'm coming at my fellow members from Riverside in Dayton Ohio! w00t!! lol. I moved down here from Salem, Ohio.
Old Oct 18, 2006 | 09:15 PM
  #528
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
1. Its a V6 Car!
2. If it was a v8 the turbo kit costs more than the cars worth, lol. Its really a piece of crap. Looks like swiss cheese.
3. Its gonna need alot more than a turbo to be cool and fast
Old Oct 18, 2006 | 09:40 PM
  #529
cam92rs's Avatar
Engine: 305 tbi
you needa keep on a coming to the zanesville or cambridge area,ive seen like 5 camaros(25th anni's) around here.,but i dont stop them.im always in a hurry lol.i wanna start a club or somthing.
Old Oct 18, 2006 | 10:16 PM
  #530
90irocz305's Avatar
hey guys...first post here on the boards. im from sheffield lake ohio. is a small town right next to lorain and avon lake, just 20 minutes west of cleveland. i just got my 90 iroc at the end of last month and it's very stock right now and needs a little body work but runs like a beast, if anyone is close enough there are still car shows at quaker stake and lube in sheffield on 254 if any one wants to get together
Old Oct 19, 2006 | 09:02 PM
  #531
camaro88rs's Avatar
Car: camaro/ 88 olds
Transmission: 5 speed
im from mogadore about 2 miles from summit auto racing and not to far from akron...
Old Oct 22, 2006 | 05:11 PM
  #532
driver's Avatar
Car: pro street 72 nova
Engine: 502 crate
Transmission: coan 400
Axle/Gears: 35 spline/486's
Columbus and it rocks.I have a 9 sec pro street 72 nova.
Old Oct 22, 2006 | 08:47 PM
  #533
Method_z28's Avatar
Car: 92 camaro z28
what day on quaker steak and lube?
Old Oct 22, 2006 | 10:10 PM
  #534
90irocz305's Avatar
they generally start rolling in around 5:00 but most of the cars get there around 7.
Old Oct 23, 2006 | 04:44 PM
  #535
Method_z28's Avatar
Car: 92 camaro z28
what day
Old Oct 27, 2006 | 07:07 PM
  #536
Heymoe29's Avatar
Car: 03 Suburban,87 Iroc
Engine: 5.7 TPI
Transmission: AUTO 700R4
Axle/Gears: ?
Another Ohioian Here
I am from Liberty Tswp, Ohio... Inbetween Dayton and Cincinnati. Anybody close to here?
Old Oct 28, 2006 | 11:30 PM
  #537
Hargrave's Avatar
Car: 1986 Iroc
Engine: 305 Carbed
Transmission: 700r4, 3200rpm Converter
Axle/Gears: 3.73 posi, rear disk
HEY!
Hi guys! First post, But I've been reading for months.
Grew up in Kettering, now living in Cincinnati.
Bought my first Camaro over the summer, 1986 Iroc.
It was a failed project that I paid way too much for.
I actually got to drive it today.. around the block counts as a drive!
Old Oct 29, 2006 | 07:21 AM
  #538
Heymoe29's Avatar
Engine: 5.7 TPI
Axle/Gears: ?
How's it going Hargrave. Are youclose to the Tricounty area or where abouts are you located. I live about 10min north of Tricounty.
Old Oct 29, 2006 | 08:04 AM
  #539
Hargrave's Avatar
Car: 1986 Iroc
Engine: 305 Carbed
Colerain Twp. About 5 minutes west along 275 from tri county
Old Oct 29, 2006 | 08:29 AM
  #540
Heymoe29's Avatar
Engine: 5.7 TPI
Axle/Gears: ?
That not far at all. We will have to hook up sometime. PM me your email address and I send some pics of my 87 iroc
Old Oct 29, 2006 | 08:35 AM
  #541
Hargrave's Avatar
Car: 1986 Iroc
Engine: 305 Carbed
Pm sent!
I'll tell ya all about the fight I've been having with this one I've got
Old Oct 29, 2006 | 05:53 PM
  #542
sure thing! let me know!
Old Oct 29, 2006 | 06:25 PM
  #543
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
Im from east Dayton and I just got a sweet Firebird off a DaytonFbody guy. It costed me $1200. I got wheel spacers in the mail for the front and I am looking for a 4th gen rear axle. Im gonna put black Z06's w/ Nitto 555's on it. This car has zero rust!! Pics of new car and Camaro in the sig. check em out
Old Nov 5, 2006 | 09:22 PM
  #544
jim86's Avatar
North Royalton here ... '87 L98 IROC.
Old Nov 10, 2006 | 01:01 PM
  #545
CashMunson's Avatar
Engine: 408 LS
i'm near you, i'm about 20 minutes east of summit in ravenna.
Old Dec 5, 2006 | 12:56 PM
  #546
CashMunson's Avatar
Engine: 408 LS
anybody have any winter plans? i'm going to work on suspension and the rear end this winter.
Old Dec 5, 2006 | 01:21 PM
  #547
cam92rs's Avatar
Engine: 305 tbi
ditto on the rear end, and hopefully i get the body work done and prepped for paint. im thinking orange with black stripes, or silver with black stripes, but now im leaning towards midnight blue metallic. i think ima go with the midnight blue, also income tax time i plan on geting some corvette wheels and spacers if i need them.another thing i wanted to do is get a high rise intake with a 4 inch cowl hood.ive got some 3.73's with a posi on the way, should be here within 2 weeks. gotta get a case of beer and a free weekend for that 1.lol. my buddies car is in cambridge and we are currently working on stripping it and pulling the motor and preping it for paint. our cars will be identical, only difference will be the wheels and ground effects.
Old Dec 5, 2006 | 01:28 PM
  #548
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Turbocharge attempt #2 for me. I'm going to build a new 350 and put the turbo setup back on the car. Also switching from carb to dfi. Some interior and suspension work as well.
Old Dec 5, 2006 | 05:11 PM
  #549
CashMunson's Avatar
Engine: 408 LS
dfi is far superior to carb, you won't regret it. single turbo or twin? what size you running?
i'm gonna add new lca's, relocation brackets, a girdle for my 9 bolt rear end, new axles, DS loop, SFC's. and possibly rebuild my tranny with a kit from pro-built. I might also throw in a new torque arm and probably an adjustable panhard bar.
the blue sounds like a nice color, i was going to do my gta in either dark green metallic or dark blue metallic
Old Dec 5, 2006 | 07:25 PM
  #550
Spdfrk1990's Avatar
hargrave your not far from me im from milford.
