Ohio?
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
all my new suspension parts showed up today at the same time. take a look. I'm also switching my car from MAF to SD, those parts are on their way to.
J&M LCA's with new polyball bushing technology
J&M panhard bar with polyurethane bushings
Spohn weld in LCA relocation brackets
Spohn bolt-in driveshaft loop
TA Performance 9 bolt rear end girdle with stud kit
Engine: 408 LS
you can definitely blame that one on me... bunch of parts show up, renew my plates, put insurance on the car.... it snows...
Engine: 408 LS
i was going to go there for the same thing. but there aren't many jobs around here for somebody with that much qualification. i decided on going to the local trade school and getting certified in welding. lots of welding jobs around here starting at 12-14 hr.
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
Re: Ohio?
Anybody near me got front lower control arms I can buy? Just to get ball joints and bushings changed a little faster...
Car: 92 Z28
Engine: Boosted LSX
Car: 92 Z28
Engine: Boosted LSX
Engine: 408 LS
Re: Ohio?
he lives about the same distance as me from you. about 1 hr.
soultron are you gonna be ready to hit that ravenna car gathering here in a couple months? i've been driving my car everyday for the last 2 weeks now.
Car: 87 trans am
Re: Ohio?
Munson,
Just started driving the T/A today. I have tokico struts for the front, but I got them used and I'm wondering if one is shot, or if the adjuster is just "in between" settings. I'm ditching my GFX. Every car I've ever had has been ugly to everyone but me, why should this one be any different. But sure, maybe we can drop in.
TPI383,
I'm at 44021. Give me the right day and I'd just pick up.
TPI383,
Car: 92 Z28
Engine: Boosted LSX
Engine: 408 LS
Re: Ohio?
Munson,
TPI383,
TPI383,
Car: 87 trans am
Re: Ohio?
Sounds like a a place to check out then, I like Go better than Show anyway. Cash, what gearing is your 9 bolt? I'm thinking of getting one, but it's 2.77 and I have a T5. I currently have 3.73s ( so I was told). do you think I would still be able to ****** them loose with my 305?
you have a PM TPI383.
Engine: 408 LS
Re: Ohio?
Car: 1985 Pontiac Trans Am - PROJECT
Engine: 412 c.i. SBC / 6.75 L
Axle/Gears: Borg Warner 3.27
Re: Ohio?
Hey, everyone... My name is Josh and I'm in Dayton. I just got back in the F-body scene. (Used to have an 89 Camaro)...
This is the new ride. 1985 T/a... 305 motor with a TBI system on a Weiand intake, 700r4 trans with Hurst Promatic shifter... (go easy on me, it was a $500 special and I have enough money to get her looking good and running strong)
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
Re: Ohio?
ya my last car before this one had much of the floor missing but was still solid with no body flex was a hard top so that helpped
Re: Ohio?
The carpet was kinda rough anyway, so I pulled it to replace it and check the floorboard. Every square inch of the floorboard is bright red and not a spec of rust.
Car: 1991 camaro RS
Re: Ohio?
look under as thats how my last car was when we got it inside was all there but they use 2 layers to the floor boards once one of the layers rusts away the next one dose much faster then the last
the problem is how thin the layers are replacement floors are 1 sheet of thicker steel
took my black car less then a year to go from inside floor clean to a large hole
Re: Ohio?
Yeah, I checked the underside of the car before I even thought about buying. It's very clean under there...
Re: Ohio?
Is there a 'southwest Ohio' F-body board? Check out http://www.dayton-fbody.com/
If there is, let me know!
Car: 87 TA
Re: Ohio?
I'm gonna try and make it but I'm not sure if I can yet. work...
the big car show in downtown massillon is tomarrow. there are always plenty of f-bodies there, but rarly 3rd gens. if you're close come on down and support em.
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Ohio?
Shyt...if theres a carshow ANYWHERE IN OHIO, Im down...just have to get my car running again. Has been sitting since before winter....waiting for me to gather some money for insurance, gas, maintenance, and of course performance parts and GOOD LOOKS parts...as I call them.
Anyway ill let all of you know when mine is up and running....then we can chill in the TGO group....I might get a sticker made for my car that has TGO websit with my USERNAME....I am going to make some up...if anyone wants some let me know...Ill make some up and post em up. Ill make a few designs...simple...nothing drastic. L8er guys.
Car: 92 Camaro RS
Transmission: T5 manual
Re: Ohio?
A number of f-body guys are going to Roby all GM car show tomorrow.
Click here for flyer
I won't be there, I'll be autocrossing.
Car: 87 TA
Re: Ohio?
the big car show is today in massillon. but there will be plenty more. every saturday night until late fall.
Car: '85 Firebird Trans Am
Engine: 383 SBC
Axle/Gears: 3.23 (every part will be upgraded)
Re: Ohio?
I'm from Newark, it's about 20-25 miles from columbus. Anyone close? I'm about 20-25 minutes away from National Trails Raceway also. www.Nationaltrailraceway.com
Engine: 408 LS
Car: 92 Camaro RS
Re: Ohio?
The Central Ohio F-body Association is having a dyno day July 14th.
IPS Motorsports
1740 D. Harmon Ave.
Columbus, OH 43223
12-4pm
$35 for three pulls w/ WB02 and boost, if needed.
IPS Motorsports
1740 D. Harmon Ave.
Columbus, OH 43223
12-4pm
Car: 87 trans am
Re: Ohio?
I need one, but don't have alot of cash. I bought one off a member here, but he can't send it before he goes on a trip. Man, this life.
Anybody around here got a spare 87 305 MAF for not too much?
Engine: 408 LS
Re: Ohio?
why do you have to go down south? i'm gonna be selling my MAF sensor once i swap to SD. not sure if i'm gonna be doing it this weekend or not. when do you need the maf by?
Car: 87 trans am
Re: Ohio?
I'm taking off friday or saturday, not sure. Great time for the MAF to get crazy.
Maybe I should switch to SD.
Car: 00 F-bird/84 F-bird/88 Formula
Engine: 3.8L/2.8L/5.0L 305
Engine: 408 LS
Re: Ohio?
http://www.78ta.com/ohio/index.htm
closest tracks are norwalk (now summit motorsports park) and thompson drag raceway. i personaly race at thompson.
Car: 1991 camaro RS
Re: Ohio?
dragway 42 is closer cleveland then norwalk
there are lots of car clubs up there and even more car shows brunswick saturday is one of the bigger shows also parmatown mall has a show
solon has a show tuesday nights
everything is less then an hour away most less then 30 min from cleveland
Car: 1991 camaro RS
Re: Ohio?
well there is neofb but the site went down
http://www.3rdgen.org/bb/forumdisplay.php?f=18 most are ne ohio posters
