Northern California Discussion board for Northern and Central California.
Roller Dyno Smog question
Old Aug 28, 2005 | 10:04 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Took my RS in for smog on Friday, the tech did a visual of everything....then backed it on the rollers and started the test....I aborted the test because my fanswitch conked out, and temp was getting high...so I never saw a complete readout...anyway, I asked the guy why he didn't do a functional test under the hood...he said it wasn't necessary. as long as everything was there.
You guys/gals have the same experience, or was this guy being lazy due to the 95* heat?
Old Aug 28, 2005 | 11:05 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
I talked to the smog tech when i got my car smoged, all they do is to make sure that everything is there. was that guy still gonna smog your car with it overheating?
Old Aug 28, 2005 | 11:19 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ya, I heard it start to ping, glanced in and saw it at about 240 and told him to shut it down...
So they didn't do a functional on yours either?
Old Aug 28, 2005 | 11:21 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
nope just made sure that everything was hooked up, although i do think they screwed with my idle adjustments, i had the idle perfect then once i got it back, i was stalling out like crazy until i warmed up.. thank *** i got a mechanical fan
Old Aug 28, 2005 | 01:11 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
They're supposed to look to make sure everything is there. They don't need to test any of it.
My smog guy doesn't even pop my hood though
Old Aug 28, 2005 | 04:13 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'll be darn...then it would be quite possible to run a set of heads w/o exhaust crossover, hook an egr valve up to the intake and as long as the numbers were good, you'd be okay....
I have to look into this more when I take the RS back to get another test on it.
Old Aug 28, 2005 | 04:17 PM
Car: '72 Chevy Nova
Transmission: TH350
yep. you can do whatever you want as long as it "looks" legal and it passes the sniffers.
Or just have the hookup and run whatever the hell you want as long as the sniffer likes it.
Old Aug 28, 2005 | 07:06 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
which is eggzactly how it should be anyway....
Old Aug 28, 2005 | 08:06 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
depending upon the tech he will do a functional they are supposed to in california it consists of a 3 part smog test functional visual and emissions,
things they test, egr valve, timing, idle within spec, mil check engine light, among a few other things,
Old Aug 28, 2005 | 08:15 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
the only real function checks that the guy did on my car was the radatior check/ and gas cap check
Old Aug 28, 2005 | 10:05 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
he like most was being lazy when I go to get my car smog'd the tech never opens the hood he just checks the gas cap and put's it on the rollers.
Old Sep 17, 2005 | 09:02 PM
sixpackmtrspts's Avatar
there are no functional tests that techs have to do other than a test of the gas cap and check the timing. technically we are supposed to check the air in the tires before running it on the dyno.
Old Sep 18, 2005 | 12:30 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
can i hotglue a egr to my intake and make it pass smog then?
Old Sep 18, 2005 | 12:31 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
i wouldnt use hot glue i would use a high Temp Epoxy or RTV
Old Sep 18, 2005 | 09:23 PM
i have seen some clever tricks, a tip if you try to fool smog guys, make it look as stock as possible, any signs of tampering tips techs off and they we'll actually look harder to see if lines have been plugged etc, thinking its an undercover car from the b.a.r.
MustangBeater20
Oct 29, 2022 09:20 PM
junkcltr
Aug 2, 2019 11:12 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
