Northern California Discussion board for Northern and Central California.
dang car...
Old Sep 17, 2005 | 09:05 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
dang car...
A few days after my oil pump swap, i found out that im leaking oil put the car up on a lift and long behold, the oil pan gasket blew up on me However i do still got good oil pressure and i have to add oil every few days im thinking either the bolt was on to tight or to loose causeing the oil pressure to "burst" the gasket, The pan is leaking ONLY in that place, so now i got to drop the pan again what a pain in the rear
Old Sep 17, 2005 | 10:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
OKay, dn'tver tighten the gasket. Use a 1/4 inch drive set, and "make the loop" around the pan on the bolts. It'lltake a few "loops" to get it correct. Keep an eye on the gasket...once it starts to "squish" out from between the pan and block...STOP.
Reason to use a 1/4 inch set is to not apply too much torque on the bolts. This is one place that less is better.
Old Sep 17, 2005 | 11:04 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Ill do that, I guess the german method(goodentight) ant the best method to use lol, once i get the some more free time, ill replace the gasket, until then, ill watch my pressure, and check my oil level daily
Old Sep 18, 2005 | 12:26 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
that sux, good luck.
did u follow torque pattern ?
Old Sep 18, 2005 | 12:30 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
no i didnt, I just have the haynes manual and all they give is the torque specs, so i just got them good-en-tight with a 3/4 drive ratchet. i have a toruqe wrench its just hasnt been calibrated in like 15 years
Old Sep 18, 2005 | 01:02 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
just weld the spot thats leaking. less hassle
Old Sep 18, 2005 | 01:05 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Its the gaskit.. not the pan itself. .I dont want to weld the pan to the motor...
Old Sep 18, 2005 | 01:20 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
yes you do
Old Sep 18, 2005 | 02:58 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
just weld it, motors problay on its last legs anyway who cares
Old Sep 18, 2005 | 07:43 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
RE: Last whiny thread
Originally posted by vindeezl
If I was you and had to reseal the pan again, I would just pull the whole motor / trans and take a p!ss on it.
Old Sep 19, 2005 | 02:15 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: RE: Last whiny thread
whens the next time your gonna pull the pan? to swap the motor, i seriously think welding it is the way to go, and at this, prolly the only way to cure the leak.
Old Sep 19, 2005 | 10:57 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
gonna pull the pan to reseal it in a week two to weeks, i got to replace some suspention parts as well.
Old Sep 19, 2005 | 08:18 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Originally posted by Firebreed
suspention
suspension
Old Sep 19, 2005 | 08:26 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Dont got a spell checker at my comp
ya all knew what i ment
J.C. Denton
Sep 8, 2015 05:35 PM
V8Astro Captain
Dec 9, 2001 05:10 PM
89Irocz23
Nov 26, 2001 08:13 PM
QwkTrip
May 13, 2001 06:41 PM
UVA3rdGen
Oct 16, 2000 08:04 PM
