Northern California Discussion board for Northern and Central California.
comming along!!!
Old Dec 28, 2005 | 01:38 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
comming along!!!
well the projects been non stop since july one thing is fixed another arises,
recently my steering column broke and my oil pressure sending unit took a ****, ironicaly i just replaced the column in my grand am it did the same thing it got slop in it and moved up and down alot.
finally got an exhaust on thanks terrell i went over and chopped off his flowmaster, and have the stock piping no cat, sounds decent.
i just got back from traviz'z i threw in a chip i advanced timing a little bit and that helped alot, changed injector constant to the new 24lbers, and disabled vats . stupid vats giving me problems.
it seems to rev better and more power but is far off and needs alot more i know theres alot more power to be tuned out.
so heres the list
u joints need to be replace about to snap
speedo converter box needs to be calibrated more
more chip tuning
need a new column
reseal intake manifold oil leak at rear china wall
make new wire set, replace cap and rotor
knock sensor is defective,
a few more knick nacks but pretty soon shell be in tip top shape and ready for suspension work
Old Dec 28, 2005 | 01:40 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
wheres the part about getting matching wheels?
Old Dec 28, 2005 | 01:41 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
forgot that i have matching wheels just cant afford to put new tires on the iroc's
Old Dec 28, 2005 | 01:44 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well i would put that up before suspension work haha. really, tires are part of the suspension if you think about it.
Old Dec 28, 2005 | 03:43 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
What would it take to get one of you to get rid of the VATS in a speed density chip? I have a stock chip here that I plan to use....Let me know...
Eric,
I just towed an 83' Camaro, would that column work? If so, I just need to wait 15 days for the junk slip...
Thanks,
Jason
Old Dec 28, 2005 | 10:49 AM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
Hey Eric-
Got your mssg the other day regarding needing a place to wrench out of the rain. I have no room at the moment. The roc and bronco are in the backyard already. I just got my tpi gaskets yesterday. if i can move the truck and get those gaskets in, maybe we will have some room.
Did you go back to qwik's and get that maf yet?
Old Dec 28, 2005 | 06:26 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Eric,
Thanks,
Jason
if you have the stock chip, it cant be touched, however if you get an aftermarket adapter through moates, its around 55 bucks i believe, i'd be more then happy to make you a chip with the basics covered free of charge.
Old Dec 28, 2005 | 07:12 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
Originally posted by irocdaddy
Hey Eric-
naww...
im using terrells haha hes not gonna use it for a long time lol
its ok i can do it at my house i just wanted to use air tools haha too many cars at the shop haha.
Old Dec 29, 2005 | 03:58 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
Hey, these slp tpi gaskets are only 1.5" dia holes....
my old ones were 1.75"
does Accell still make em' I think that was the brand of the bigger ones.
I'm putting these in anyways.
Old Dec 29, 2005 | 07:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Have you thought about repairing your column? Usually when they get wobbly, the inner 3 (or 4) bolts come loose.
I've had good luck taking them apart and putting locktite on the loose ones. Takes a lockplate depresser, a small metric (don't recall the size) bolt to yank the tilt pins out and a hour or so of your time.
This is assuming you don't have airbags, since I've never done an airbag wheel before.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
BADNBLK
Nov 16, 2016 09:12 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
