Northern California Discussion board for Northern and Central California.
350
Old Mar 13, 2006 | 06:58 PM
IrocThemRicers's Avatar
Car: 1971 Camaro
350
yeah I check craigslist everyday for cars that are of interest. Are the 305's pretty quick? Or should I try and pick up a 350 if I can afford it?
Old Mar 13, 2006 | 07:17 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
if u plan to mod it in the future, stick with the 5.7
remember, 350's only came in auto unless its been converted so dont be fooled.
Old Mar 13, 2006 | 11:31 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
You might want to think about what's more important to you, a 5-6 speed or a 350. 305's came w/ both auto and 5 speeds. 350's came stock as auto only. I went with the 350 and plan on converting to a 6 speed later(Kiesler), 'cause I didn't want to mess with smog crap, and wanted the extra hp. Some people(drag racers) prefer the auto trans though. Most would say to steer clear of the 305. I had one(5.0 HO motor) in my 84 that was noticably weaker than my current 350. Very happy with the IROC I have now. But want more than stock hp later. Right now it's a daily driver though.
Old Mar 13, 2006 | 11:32 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Also TPI is a nice intake for stock vs. carb, but there are some who swear by carb.
Old Mar 13, 2006 | 11:34 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
IE Me.. even though my car is running like crap atm... i'm thinking its time for a carb rebuld .. if only i knew how lol
Old Mar 13, 2006 | 11:41 PM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Firebreed, have you tried carb cleaner spray as an eay fix yet? Sometimes the easy fixes you don't think about. The other day, I replaced my fuel filter when at first I thought my fuel pump was going out.
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I'd get the cleanest car I could, and its easier to go from 305->350 than it is to go from auto->manual
Old Mar 14, 2006 | 12:03 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
ive done just about everything i can think of.. now i just got to figure out why in the hell im smelling gas! i see no leaks, i think by the end of this week im gonna get this car up on a lift and give the gas lines a good inspection.
i used carb cleaner.. i got the carb nice and shiny.. but other then that no difference.. hell i even adjusted the idle speed screw to get the car to idle lower (cant seem to get it under 1k on my stock tach...) lately its been almost dying but then comeing right back alive, its like its stumbling, but it doesnt do it all the time. I do know that (look at the picture) that thing is not doing what its supposed to be doing (forgot what it is called). Its supposed to stop the car from deseling after shutdown. sorry bout the size.. BTW the carb looks much cleaner now then it does in the pic.. Ive used about 2 to 3 cans of carb cleaner on the carb since then (and no not at the same time)
(its at the bottum right hand corner, you can barely see it)
Old Mar 14, 2006 | 12:06 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
BTW.. sorry bout hijacking the thread lol
Old Mar 14, 2006 | 12:12 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
Yeah, oops on the high jack. Have you priced an upgraded carb? How far from your motor swap?
Old Mar 14, 2006 | 12:16 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
3.4 swap is gonna be at least a year away (got to save some more money) I keep blowing my engine money on other things for the car (ie: suspension upgrades, ect ect)
I priced a 2bbl holley (a holley II, which is a remaned Verajet.... i believe) at 400+
I bet i can get a local shop to rebuild my carb cheeper then that.
Old Mar 14, 2006 | 12:18 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
For sure, espeacially if you take it to them. Might want a shop to look at the other issues though. Sorry about the misfortune though. If it makes you feel better my wifes Tahoes trans went out at the cost of $2200.
Old Mar 14, 2006 | 12:24 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Im reall iffy about taking the car to shops.. the last shop i took it too, f'd up my a/c system.. had a/c in the car for a week after a r134a swap.. a year later i replaced my compressor, acummulator, and found out that the line where the a/c filter goes (orface tube?) was striped out (the nut part... *** that sounds wrong )
Old Mar 14, 2006 | 12:28 AM
Daniel U's Avatar
Car: '88 Camaro
Engine: 5.7 L98
I plan on pulling mine eventually if you want it. I need the A/C delete pulley though. Good mech. are hard to find. The guy with the ruff 92 was/is a mechanic. He might steer you n the right direction.
Old Mar 14, 2006 | 12:31 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
all i really need i believe to get this car's ac going again, is a good shop who will do a good leak down test other then just giveing it a good once over (which the past two shops did... ) and replace just about every hose, hardline, ect of the a/c system. then charge it up with r134a
Old Mar 14, 2006 | 01:48 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Firebreed, rebuilding a carb is E-fukin-Z.
You can waste all the cans of carb cleaner on the outside you want and make it all pretty, but it will still run like $hit.
Sounds to me like you have a couple of clogged idle passages / needle & seat, or need to fiddle with the float.
All in all some of your time and a $20 rebuild kit will beat $400.
Couldn't agree more bro
Old Mar 14, 2006 | 01:53 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Im just hopeing that that is all that it is, gonna buy the rebuild kit and let a shop rebuild it for me.. dont feel like screwing anything up in the carb (one thing i dont want to do is screw up the carb, and have to buy a remaned one cause of it) besides, the shop should have all the tools to do it.. I dont
Old Mar 14, 2006 | 02:06 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Well the tools req'd to rebuild a carb aren't exactly "specialty" tools. It's not like you need an electron microscope and a hydraulic press to do it. IMHO you should have this crap already.
It is your fear of "screwing anything up" that will keep your local auto repair shop in business. To be honest, if it wasn't already "screwed up" then you wouldn't be trying to do anything now, would you? IMO anything you try and do would be an improvement.
What if it is just a clogged needle / seat, total cost ~$20 rebuild kit included.
But feel free to put your mechanic's son through college, I'm not
Old Mar 14, 2006 | 02:13 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
I might just try to rebuild it myself, if i screw it up then ill take it to the shop and have it professionally redone
Old Mar 14, 2006 | 02:16 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
'Atta boy! Growin' you some *****!
Just rip that P.O.S. apart and you will never bow to it again, you will know it inside and out. No "if i screw it up", just do it until you fix it.
Your wallet will thank you, you will have peace of mind that it's done right.
Old Mar 14, 2006 | 12:35 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
It's really not that difficult Firebreed. I've done a couple carbs at our shop and it's not that big of a deal. Just make sure you don't loose ANYTHING. Also, set aside some time to work on it straight from start to finish. If you don't have to divide your time, you'll be able to finish it much easier.
Old Mar 14, 2006 | 12:43 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
The carb kits come with everything right? (including all those sensors in the carb?)
Old Mar 14, 2006 | 02:02 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
I sincerely doubt it would have any sensors, just the gaskets / O-rings for them so you can clean / re-seal them.
Old Mar 14, 2006 | 02:07 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
one could hope eh? lol
Old Mar 14, 2006 | 04:32 PM
JMJ2003's Avatar
Car: A beater.
Engine: Not enough HP.
Transmission: Automatic... I can't drive a stick!
Brandon, just rebuild it yourself.
If I can do it and not f*ck anything up, you can do it too!
Old Mar 14, 2006 | 04:39 PM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
