Northern California Discussion board for Northern and Central California.
stroke
Old May 31, 2006 | 12:05 PM
MY84CAMARO06's Avatar
Car: 1984 CAMARO
Engine: 305 H.O Z28
Transmission: 5 SPD
Axle/Gears: DONT KNOW MUCH ABOUT CAMAROS
stroke
can you stroke a 305?if not how is a 383 built?
Old May 31, 2006 | 12:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes you can. Just the way a 350 can be stroked to a 383, a 305 can be stroked to a 335. Mostly it's a waste of time and money though.
Old May 31, 2006 | 01:18 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I wouldn't say its a waste of time and money, because hes running a carb'd motor if it was a tpi(stock long runner design) it would be a waste. the problem with the 305 is the size of the cylinder bore is small, so to make power you have to spin the motor at a higher rpm. all depends on how much power your looking for. you can take the 305 rebuild it throw some mods at it and have a quick car.
Old May 31, 2006 | 07:42 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
305's are still limited with the small bore so you can't run a larger valve.
A 383 isn't a waste of time though imo.
I know with LT1 blocks you can stroke them to 396s, 406s, 412s and a 421 if you really want to push it. I never see Gen 1 350s past a 385 though.
Old May 31, 2006 | 09:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, the problem with the 305 is the size of the cylinder bore is small, so you can't use a decent-sized valve, which limits airflow. If you can't flow air into it, you can't spin it to higher RPM to make the power anyway.
The additional cost of 335 pistons compared to 383 pistons pretty much makes up for the cost of a bare 350 block to rebuild.
You can throw some mods at a 305 and have a quick and fun car, but if you're going to do anything at all to the bottom half, you're a whole lot better off starting over with a 350 block.
Old Jun 1, 2006 | 12:27 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
bah there u go praising your lt1 again lol.
if u count aftermarket blocks, u can get a smallblock (highly modified) to cover enough ground for 454 cubic inches thanks to World.
but hey my next engine is gonna consist of the warhawk block, ls7x. its gonna own someday!
JEGS High Performance - World Products Warhawk LS7X Blocks
just a bit overkill
Old Jun 1, 2006 | 01:34 AM
Car: '72 Chevy Nova
Transmission: TH350
just a bit overkill
Actually I was commenting, hoping someone would know of a 350 someone stroked out that far, because it's really cool. And since the two blocks are very very similar internally, I don't see why it couldn't be done. But like I said, I don't think I've ever seen one.
And yes I know 454 gen 1 smallblocks are available. They sell an aluminum 454 small block LT1 as well It was originally a custom one-off, but the guy sells them now to anyone who has a few thousand laying around.
I'm curious if you can stroke the small block 454 to something bigger or if it's "maxxed out". I know a BBC 454 can be stroked to damn near 500 cid, like 490 something.
Old Jun 1, 2006 | 01:51 AM
kairles's Avatar
Engine: 383/LGX
a .030 over 350 with a 3.875 crank is a 396, sure its the same as an LT1
Old Jun 1, 2006 | 02:09 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
what about the 572?
Old Jun 1, 2006 | 07:41 PM
Car: '72 Chevy Nova
Transmission: TH350
A 572 is a stroked 502 block iirc
Old Jun 2, 2006 | 02:34 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
its still sweet!
Old Jun 2, 2006 | 12:48 PM
JesasaurusRex's Avatar
I know somebody makes a 472 small block
Old Jun 2, 2006 | 01:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I believe I've even heard of a 502 small block. They're not really conventional small blocks though, they're aftermarket blocks with tall decks, spread rails and raised cam centerlines. Only the bore spacing is the same.
Old Jun 2, 2006 | 02:33 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
its a frankenstein!
junior419
Apr 7, 2025 11:35 AM
randy210
Oct 15, 2015 03:43 PM
dusterbd
Sep 29, 2015 08:40 AM
C409
Sep 23, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
