help me, cant start the car.
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
I can't get the engine to crank when I turn the key to start. I did apply 12volts to the starter and it does start manually (hot wired).
I am not sure if I wired it correctly. I have 2 big gauge red wires powered 12volt consistantly to the interior of the car through the c100 connector (the one at the drivers side firewall)
and I ran the heavy gauge purple wire to the s-terminal on the starter. No go.
Can anyone give me some tips? Did I do it wrong? I tried the other remaining wires to the S terminal as well, no luck. The heavy gauge pink wire does get 12volts under start and run. so when I turn the key to on, it cranked the starter, we definitely don't want that.
what else can I check? Or who wants to look at how their starter is wired for me?
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Re: help me, cant start the car.
Do you still have the factory starter relay in place? There is a yellow wire that comes off of the ignition switch, and it is only energized when the key is turned to start. That wire supplies the relay with power, then the relay closes and sends power through the gear selector switch, then to the purple wire which goes to the starter. You know the starter works, so maybe you wired your starter relay incorrectly?
Car: '02 Z06
Engine: L33 5.7
where is this starter relay located? under the hood or under the dash? if it was under the hood, chances are its no longer their. if its under the dash, it has not been tampered with, but has sat for over a year..
Axle/Gears: 3.73:1
It should be under the dash, and plugs into the body harness. Ultimately you need to figure out how to get the yellow wire that comes out of the ignition switch to supply the starter power where the factory purple wire attaches. So, using the diagram I posted, assuming your starter relay and gear selector switch are still intact (so you can't start the car in gear), you just need to run a wire from the gear switch to the starter.
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Car: '02 Z06
Engine: L33 5.7
He's just mad that his anti-smog machine took a crap on him cuz their is no dummy light to tell you when you hit 300 degrees.
Back on topic-
Jeremy, does it help to know that my trunk switch does not work as well? I know this is powered in conjunction with the starter relay.
Back on topic-
Car: '02 Z06
Engine: L33 5.7
I checked it out, I found the starter relay, its a bitch to get to, I want to assume its ok, I should probe the ignition switch for 12volts where the yellow wire exits.
If I get too frustrated I am gonna thirdgenify it and install a push button start :\
Axle/Gears: 3.73:1
Car: '02 Z06
Engine: L33 5.7
someone in the other thread mentioned vats locking up because no more factory ecm. I may try to bypass that relay.
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Travis,
You can always get the key start wire as it come out of the steering column for you power to the starter motor. Sounds as if your not using most of the factory wiring for the ECM so it will not matter that your bypassing it. Just run that to a starter relay and you will be good to go.
Brett
Brett
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
TraviZ Man life is great in my new/used mustang ... It is just awsome not worrying if it's going to make it to work and if it breaks down hahahaha someone else gets to work on it and I get to enjoy the day with my kid the under a hood ..... Don't hate me cause I have a better car.
Axle/Gears: 3.73:1
Yeah, I was under the impression you ripped all that factory stuff out. It would be very, very simple to bypass the VATS if that is what you want to do. You just need to get that start signal to the starter, as said above.
Nowthebadnews... didn't you have a TTA? What happened to that?
Car: '02 Z06
Engine: L33 5.7
Its ok NowTheBadNews, I can just hop in my reliable 98 z28 and run circles around your pony all day, and this project iroc of mine will be well worth it when its running. It will pull in looks like you would never imagine, and of coarse run circles around anything you show up in.
Engine: 4.0 V-6
I could borrow my friends vette I'm sure it could put the hurt on that LS1.
I still have it. But can never be smog legal it's just my toy to mess around with.
Last edited by NowTheBadNews; Apr 10, 2008 at 03:55 PM. Reason: Automerged Doublepost
Car: '02 Z06
Engine: L33 5.7
resorting to 'friends' cars now are we? can you hurry and go find yourself some lame mustang forum.
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Originally Posted by NowTheBadNews
Nope I resorted to great fuel mileage and great looks.
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Looks are completely subjective so I'll do you a favor and pretend you didn't say that either. As for MPG.....19 city and 28 highway EPA rating for the V6 mustang I believe? Absolutely fantastic, seeing as you would be embarassed by a stock LS1 camaro almost a decade older rated at 18 city and 27 highway.
Car: '02 Z06
Engine: L33 5.7
Hey Jeremy, I disconnected the plug from my ignition switch and probed the yellow wire, under cranking, I get no voltage. Time for a new ignition switch?
Car: '02 Z06
Engine: L33 5.7
Besides this ignition switch issue, (waiting on jeremy's response.) I come to find out my accel gen 6 ecm is missing, Probably went missing a while back when my tools were stolen, never noticed it gone until I looked for it last night. So, Car will sit a while longer until I decide on what to do. Maybe splice my wireharness into a megasquirt system? I will be found lurking the boards over at msefi.com...
Engine: 4.0 V-6
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
NowTheBadNews - Your posts have been less than useful.
Please refrain from keeping this thread off track.
Thanks in advance.
Thanks in advance.
Car: '92 Z03
Engine: LSX
Transmission: M12
I bet that damn thing ain't cheap either, sorry to hear that bro.
Axle/Gears: 3.73:1
As for the ECM.. damn dude, that sucks. If I were in your shoes I'd probably get a Megasquirt to get the car up and running.
Car: '02 Z06
Engine: L33 5.7
Both red wires leading into the ignition switch has constant 12volt. I will run outside and check the plug leading into the switch for 12 volt as well. I am confident it is however since All accessories inside the car work as intended now.
I am thinking megasquirt as well, I am reading alot about it. Would not be hard to repin my accel harness into a MS box. Be a month away before I buy the 421 dollar unit however.
Car: '88 Camaro
Engine: 5.7 L98
Axle/Gears: Borg Warner 9 bolt w/3.27 lim. slip
Car: '02 Z06
Engine: L33 5.7
To bring closure to this thread, I tried everything and Can't figure it out. So I installed a pushbutton.
Is this considered *******/thirdgenish?
or cool because all the new hi-tech cars have it?
I think steve would appreciate it.
Axle/Gears: 3.73:1
It's your car bud.
So did you wire that through the factory ignition switch wiring?
So did you wire that through the factory ignition switch wiring? Supreme Member
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
cool, atleast you don't have one of those "ENGINE START" buttons tht you see on the *****s
Car: '02 Z06
Engine: L33 5.7
Travis,
So update. Where are you at? I know you said you needed an ECM. Is the car turn over and everything else ready? Did you get your stainless Steel ducting done?
Car: '02 Z06
Engine: L33 5.7
No im saving for the ecm now.
the welding still needs to be done but thats on the back burner.
Car: 02 Chevy Impala
Engine: 3.8L V6
Axle/Gears: FWD
I like the push button setup bish, looks really clean, like it was built there from the factory
I would still someday fix it right though, just for the heck of it, but you know how I am
For now it works
For now it works
