Northern California Discussion board for Northern and Central California.
that pile of garbage they call the sbc
Old Oct 13, 2008 | 02:39 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
well got the 350 out of the iroc on a stand and i found out what was wrong and why it knocked n crap
the damn 50yo design they couldnt fix the flaws and had to make **** so cheap
the oil pump pickup was sitting at the bottom of the pan and had fallen out of the pump, so that explains that when i first noticed the oil pressure dropping slowly than i noticed the knock happened when it fell out and that = dead motor if theres no lube.
so all the rods and everything were f**ked
Old Oct 13, 2008 | 01:18 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: that pile of garbage they call the sbc
I blame the installer.
Old Oct 13, 2008 | 02:26 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
ya who ever built my engine from the factory must have been a friday cause it was freakishly fast for a stock turdgen but the damn press fit oil pump pickup came out
seriously chevy wouldnt be that hard to add a bolt in there or weld it in place.
Old Oct 15, 2008 | 12:24 AM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
It happens, it doesn't matter if its Ford, Nissan, or Chev...
They are all mass produced, it doesn't matter if its made on Friday or Monday. There is a quota per day.
It just happens, and when you see something dropping out if its specified range, thats when you stop & find out whats wrong. Thats why the put gauges in car. Unfortunately stuff happens so fast, if its not caught soon, its too late!
Old Oct 16, 2008 | 06:30 AM
fryer1979's Avatar
Car: '79 Camaro; '84 Z28
Engine: 350; none
Transmission: TH-350, 2500 stall; none
Axle/Gears: posi, 3.08; disc, 3.23
how many miles does the car have on it? There are a lot of problems associated with mileage and repairs/modifications with any engine. What I mean is: Take a Chevy 350 (or any motor of your choice), and put 180,000 on it. Let's just say this motor is not modified at all, pure bone stock Dad's pickup. Dad blows a head gasket and needs to have it replaced. While the heads are off of the enigine the mechanic talks him into going completely through the heads, and making them good as new (an easy sell by the way). This may sound like a good idea at first but consider that the entire engine is worn in together, bearings, rings, gaskets, and seals. Now imagine what a freashly sealed set of heads will do to an old worn bottom end? They will quickly blow out the sealing surfaces of the rest of the engine, and leave dad more pissed off than ever. It is a simple "path of least resistance" physics issue. I have been turning wrenches for many years and this happens EVERY time I have seen new heads put on an old engine; in fact, I stopped doing this for customers a long time ago. The cylinder head example is just that, an example, I am not saying that this is what happened with your car. I am new on this site and do not know your car or you at all. Just bringing up an issue I have dealt with many times. It very well could be a factory screw-up, just something else to consider is all.
Old Oct 16, 2008 | 02:17 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
mine only had 100K on it
oh well
Old Oct 16, 2008 | 05:06 PM
Vash Vega's Avatar
Car: 1990 Iroc Z,2004 Z06 Corvette
Engine: 5.7 L98 tpi/LS6 346 ci
Transmission: 700r4/MN12
Axle/Gears: 10 bolt 3.23/DTE 3.42
i got my heads rebuilt on my original motor with over 180xxx miles and haven't touch the bottom end and my motor still runs great and i beat on it sometimes also
Old Oct 16, 2008 | 07:44 PM
fryer1979's Avatar
Engine: 350; none
I can only speak from my own experience, and the fact that a majority of the engines I replace have had new heads put on them rescently. I am sure exceptions exist, I just have not eperienced it yet. Have you put all of those 180K on yourself? I am really kind of curious, you may have my first exception. As far as the oil pump mater goes though, 100K just does not seem like enough miles. Factory defective parts are definitly not uncommon. With the allowable variations in manufacturers specs, it truely is a wonder more parts don't fail prematurely. Sorry about you luck my friend. Just a couple of years ago I had an intake manifold gasket blow and let water into the oil. Car started runnig a little funny on my drive and by the time I got to my garage it had one hell of a knock. I know the feeling well.
Oh, also how long (mileage wise) has it been since you had your heads rebuilt? This problem of course is not immediate, however a majority of the cases I have dealt with happen within 12,000 miles.
Old Oct 16, 2008 | 10:14 PM
Vash Vega's Avatar
nope i bought the car from my cousin last yr with 175,000mi the motor was real strong it grenaded my 700r4 last yr around December lol so i got the heads & transmission done at 188k the exhaust valve seals were bad and i wanted to change the head gaskets so the motor would be solid till i start my ls2/t56 swap sometime next yr so i took the heads off and just let the shop did a valve job,resurface the heads and put new seals in only cost me 160$ and my car been running strong ever since
Old Oct 16, 2008 | 10:21 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Now I see why we dont get along, are you even old enough to vote?
Old Oct 16, 2008 | 10:38 PM
Vash Vega's Avatar
skinny little boy im 21 yrs old
you get your weak pitiful camaro alley site back up
Old Oct 16, 2008 | 11:00 PM
fryer1979's Avatar
Engine: 350; none
I hate to break it to you bud, but you are only beginning the path of your motor's doom. If it survives another 10,000 then you can say it didn't happen. Fortunately for you it sounds like you have your motor swap coming soon, so the engine should last you until then.
Old Oct 16, 2008 | 11:08 PM
Vash Vega's Avatar
it should survive past 10,000 it had good compression when i got and it still does,my car actually feels faster than when i bought it last yr
Old Oct 16, 2008 | 11:15 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Originally Posted by Kidd Vette
skinny little boy im 21 yrs old you **** sucker
I don't mind seeing the bickering back and fourth between you two, but dude, this type of post should get you banned, period! Immiture, zero class, on and on.... I have no idea who you are, but you are obviously an idiot, you have proved that...
Mods, please at least delete his post....
jason
Old Oct 16, 2008 | 11:21 PM
Vash Vega's Avatar
jason
yup you don't know me and mind your own business im just tired of people always starting crap with me,its immature not immiture learn how to spell if you going to talk crap
Old Oct 16, 2008 | 11:25 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
yup you don't know me and mind your own business you im just tired of people always starting crap with me,its immature not immiture learn how to spell if you going to talk crap
You are the last person that should try teaching grammer.... I have read through many of your posts and assure you that my 8 year old son has a better idea of how to form a sentance than you. I am not "talking crap" , you have been the one doing plenty of that. Take your BS elsewhere!
Old Oct 16, 2008 | 11:28 PM
Vash Vega's Avatar
i read some of yours posts too and,im lazy on the the keyboard sometimes and i bet your son can drive and do a motor swap as well huh
Old Oct 16, 2008 | 11:44 PM
fryer1979's Avatar
Engine: 350; none
Like I said man, I can only speak from experience. I have been a professional wrench for 10 years, and have been involved in many F-body projects (as well as tons of other performance cars). It is just what my experiences have taught me, and it is not a matter of my own work either, most of these jobs come to me from other more "established" shops. Hopefully your experience is different than mine, I would hate to see another F-body off the road.
Old Oct 16, 2008 | 11:51 PM
porkyzilla's Avatar
Engine: 5.7tpi 350,
i dont consider a shop a reputable shop if it wants to rebuild heads or do headgaskets on a 180K mi motor they are nuts, you get a lower mileage long block with a warranty or rebuild the whole motor.
thats just asking for trouble to do heads or head gaskets on something that old.
and the pump wasnt defective from the factory the design was
Old Oct 16, 2008 | 11:56 PM
Vash Vega's Avatar
i installed the head gaskets and heads,the motor might be a rebuilt not sure because the old head gaskets were blue fel pro gaskets you get in a kit
Old Oct 17, 2008 | 12:12 AM
fryer1979's Avatar
Engine: 350; none
granted a locking bolt would be nice, but your mishap is the first I have seen do what yours did. maybe someone else was in there and put a new screen in from the wrong year, or maybe tried to clean the crean and re-use it. I don't know, it is confusing and amusing to me. I would like to be there hands on with this engine, sounds like another good opportunity to learn. BTW have you got it running yet? I saw you were working on another engine going in.
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
regerster a new name and start over, you will never get respect here with your name.
Old Oct 17, 2008 | 12:17 AM
Vash Vega's Avatar
lmao you again why don't you REGISTER a new name and scribble your old one out
Old Oct 17, 2008 | 12:22 AM
Vash Vega's Avatar
i don't need your respect or anybody's from the internet i could care less<br>
Old Oct 17, 2008 | 01:06 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
nope havent gotten it running yet that old motor needs lots and lots of machining,
this motor has never been opened cept for me, the oil pump has a date code of 88 on it and my car is an 89 it fits, i also bought it from the orignal owner with 75K on it he gave me paperwork on everything ever done
its a known thing when ever you get a rebuild or build a sbc you weld the pickup to the pump after you set the depth ive had this done numerous times
oh well i could always use some reliable help. ill pm ya
Old Oct 17, 2008 | 02:59 AM
fryer1979's Avatar
Engine: 350; none
Strange, very strange.
Old Oct 17, 2008 | 09:31 AM
kahless's Avatar
Car: 89 Firebird Formula
Engine: chevy 5.7 V8 TBI but carbed soon
Axle/Gears: no freakin clue lol
Guys Guys cant we all be friends lmfao!!!!!
Old Oct 17, 2008 | 11:29 AM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I'll deal with this thread later.
You should all know what a productive post is by now.
There is no room here for negative banter.
Old Oct 17, 2008 | 01:35 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Wow if I had the extra time I'd quote all your posts, Kidd Vette, and bold all the spelling and grammar mistakes you just made.
For right now just calm down and stop acting immature yourself. This is an Internet forum for enthusiasts of Third Gens, not a site for "E-Thuggin'" trying to show off your obvious lack of college level English education. If you want to E-Thug by being a grammar **** I'd suggest at least using the grammar/spelling checker on your own posts before you try to hijack.
Old Oct 17, 2008 | 01:48 PM
Vash Vega's Avatar
yeah whatever ill stop being immature like some people on here
Old Oct 17, 2008 | 02:00 PM
Vash Vega's Avatar
from here on im stopping the bs and ignoring immature,ignorant,uneducated,internet grammar correction police lmao peace
Old Oct 17, 2008 | 02:19 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
From here on
^ capitalization
I'm stopping
^spelling & capitalization
the BS and ignoring
^capitalization
immature, ignorant, uneducated, internet
^ space ^space ^space ^ space
grammar correction police,
^comma
lamo peace.
^spelling ^ punctuation
Your sentience structure could also use some help, but we will leave that for another day.
Have a nice day.
Old Oct 17, 2008 | 02:24 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
I am not posting for any other reason than to appolagize for getting involved with this nonsense. I have been a member of this site since 1999 and have yet to have an issue, no need to begin now, I am above that. I will let the moderators do what needs to be done... I'm out.
Jason
Actually, sorry for jackin' the thread Eric...
Jason
Old Oct 17, 2008 | 02:46 PM
Vash Vega's Avatar
From here on
^ capitalization
I'm stopping
the BS and ignoring
^capitalization
^comma
lamo peace.
Have a nice day.
good job you need help with you spelling write that in your dol book,like i told you in the last thread im not gay stop talking to me i don't know you and i don't swing that way and don't private message me again you get that slow *** gta running yet
Old Oct 17, 2008 | 11:27 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
lets take it to the track guys, kiddy vette, bring that z06 against my lame *** 3rd gen.
Old Oct 17, 2008 | 11:57 PM
fryer1979's Avatar
Engine: 350; none
LOUD, FAST, REAL! That's all that matters.
Vintageracer
Sep 24, 2017 12:34 PM
gixxer92
May 18, 2017 11:20 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
okfoz
Oct 13, 2015 02:19 PM
Bradsaundry
Oct 7, 2015 04:35 PM
