Northern California Discussion board for Northern and Central California.
Car Troubles
Old Jan 12, 2011 | 07:08 AM
Tha89rocfast's Avatar
Car: 1989 Camaro Iroc Z-28 5.7 TPI
Car Troubles
I have a 89 Iroc 5.7 TPI the last couple of weeks my car starts up idles for a little bit and than stalls out. I'm very confused with no clue. I already did a major tune up. Changing out plugs, wires, cap and rotor, iac, tps, icm and did a cleaning of the iac port. If you have any suggestions let me know please.
Old Jan 12, 2011 | 09:15 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Car Troubles
Im not a TPI guy. But check your fuel pressure make sure that is within specs. (im not sure what TPI fuel pressure specs are supposed to be, but I would guess 35 PSI or so) If that is okay. Your best bet is to go to the TPI section of this site and tell them your problem, and they can steer you in the right direction. This site has some of the best technical advice I have ever seen on a forum.
Old Jan 12, 2011 | 09:42 AM
Re: Car Troubles
Thanks appreciate the information I'll get that checked out.
Old Jan 12, 2011 | 09:40 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Re: Car Troubles
If you think you've covered your spark aspects, prob time to check out the fuel system. Pump ok?
Old Jan 13, 2011 | 12:20 AM
vindeezl's Avatar
Car: '92 Z03
Engine: LSX
Transmission: M12
Re: Car Troubles
Bad fuel injector
Ohm check them all, replace all in my opinion
Old Jan 13, 2011 | 12:34 AM
Car: '89 GTA
Re: Car Troubles
Old Jan 13, 2011 | 07:20 AM
Re: Car Troubles
Im not sure about the pump I haven't changed that since I bought the car in 2001. No telling when it was changed. The original owner had it sitting in the garage. How would I go about checking if it was working properly?
Old Jan 13, 2011 | 07:22 AM
Re: Car Troubles
Originally Posted by vindeezl
Bad fuel injector
Well when I drop my new motor in I put in all new fuel injectors. If I wanted to check how would I do that and how many ohms im I looking for?
Old Jan 13, 2011 | 09:45 AM
Car: '89 GTA
Re: Car Troubles
You'll need a fuel pressure gauge.
Could be pump, relay, fuse. Plugged fuel filter. Injectors like Vin said.
Old Jan 13, 2011 | 09:55 PM
wddavis's Avatar
Car: 83 z28/ 82 trans am
Engine: stock? 305 w/crossfire
Axle/Gears: 3.73/stock 2.98?
Re: Car Troubles
don't forget about the oil pressure sender, it has a switch for the fuel pump in it. if you don't have a spec on the injectors, look for different, too high or too low. a trick I have had some success with is to pull the fuse for the injectors; one bank at a time, that can help to prove weather it has anything to do with injectors sometimes the engine will run good on one bank, and not even start on the other. if the fuel system is o.k. (and you don't have a scanner) you could try unplugging load sensors like tps, map, maf...also o2 sensor(seen on fords more then G.M.)
When it dies does it sputter, or just quit, will it restart right away or does it need to sit?
P.s. you own a G.M. they loose fuel pumps a lot, ever if it is not bad now chances are that some time it will. go to sears and get a fuel pressure tester, a vacuum gage and a volt/ohm meter you will not regret any one of those tools.
Old Jan 13, 2011 | 10:07 PM
wddavis's Avatar
Re: Car Troubles
wow sorry just reread your original post with all the parts you have tried, you might want to find a trustworthy shop (after testing the injectors) sometimes the price for diag is well worth the sticker shock. We have tools and experience that is well beyond what any do it yourself person would ever need or want.
Old Jan 13, 2011 | 10:51 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Car Troubles
That's what I would recomend
Old Jan 15, 2011 | 05:58 PM
Friskyfingers's Avatar
Car: 83' Camaro Z28
Engine: 305 V-8 CrossFire
Transmission: 700-R4
Re: Car Troubles
So.....what do I get after putting 2 new tires (2days ago) New rear shocks (1 wk ago)? Need to rebuild the 5 spd tranny in my baby. Walter's not happy. Neither am I! I have been babying her for the last month because of the rear tire issue. I want to rebuild it but was waiting until next fall so I could do it in the auto class. Looks like I am getting the lesson's a lot sooner, I hope. Any suggestions???
My opinion about my car still stands about Camaro's: There like kids, always need something.
Old Jan 15, 2011 | 07:23 PM
PASTY_WHIP's Avatar
Car: 91 CAMARO RS
Engine: 305 TBI
Re: Car Troubles
I love the knowledge on this forum. U guys can cover and come up with everything. In that case I need a new Lingenfelter blown LS2 for around a grand. Delivered.....and installed. Ready set Go. LOL
Old Jan 15, 2011 | 11:11 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: Car Troubles
Try reading any stored fault codes? They're not always accurate but can point you in a general direction. Basically you need to find out what is stopping the car from running. It's not losing AIR, so that leaves only fuel and spark really. Figure out which one you don't have and then at least you know which system to go after.
Also it being an 89 car, should me MAF, tap on the mass air meter with the handle of a screwdriver while the car is running. Any change in idle characteristics or it dying would pretty much condemn the mass air meter.
These cars are not really complicated, but their systems tend to intertwine so grab the ETM's and make sure you understand what you're look at, sometimes it's right in front of you.
Will
Old Apr 29, 2011 | 05:19 PM
camaropower88's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: L98 350 TPI
Axle/Gears: 2.77 posi
Re: Car Troubles
My 88 iroc 5.7 TPI has this same issue. It started when it got cold out, it would start up, then sputter out and stall. Start it back up and its like nothing happened. But it got worse, now it stalls about 3 times before it wants to run and when it finally runs, it runs like ****! I have replaced the cap, rotor, plugs, wires, 24# bosch injectors, fuel filter,intake gaskets, cleaned the whole intake manifold, plenum, runners, TB, and IAC and its passage way, PCV valve rattles when i take it out, EGR was replaced about a year ago, and the o2 sensor about 7 months ago. Recently threw a code for MAF 33 and 36, a new connector on the MAF and relays fixed this. My biggest problem is it idles rough, it sounds like I got one of those ***** thumpr cams in it! but sadly it doesnt and its BAD haha and also wants to stall if i snap the throttle quickly. Hesitates a little on light throttle and a little at WOT but then goes. Put a 5 gas analyzer on it and its running WAY lean. I do NOT know what the fuel pressure specs are for these cars but, at idle I have 30 PSI which sounds low to me, and the when i pull the vacuum off the FPR i get 40 PSI. Do i need a new fuel pump???
bryan623
Mar 22, 2021 06:43 PM
Linson
Aug 21, 2015 02:12 PM
hokis
Aug 9, 2015 03:57 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
