Northern California Discussion board for Northern and Central California.
86 Z28 engine help
Old Aug 5, 2011 | 07:43 PM
checker's Avatar
86 Z28 engine help
I have an 86 z28 305 carb. the problem is that the car overheated and i was told i might need to replace the the heads(this is second time i need to replace them). How do i find out if the heads are actually bad
Old Aug 5, 2011 | 08:27 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: 86 Z28 engine help
heads? more than likely you'd need head gaskets. You have water in the oil? blowing exhaust out of the radiator?
Old Aug 5, 2011 | 08:46 PM
checker's Avatar
no water in oil... car just shakes alot when on
Old Aug 5, 2011 | 08:51 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
So it is missing? You need to determine why it is missing. Spark, fuel, air/compression. If you are missing, or have weak of one of those then you'll have a misfire. A bad head gasket, or bad valve's can cause a lack of compression to cause a misfire. Those are things that are why you'd need to have the heads removed. I'd start the basics. Check spark, perform full tuneup. Then go to fuel which is probably fine.
Old Aug 5, 2011 | 08:59 PM
checker's Avatar
i was told that the spark plugs are good i watch the guy check them.. whats included in a full tune up?
Old Aug 5, 2011 | 09:05 PM
checker's Avatar
tune up should be good
Old Aug 6, 2011 | 01:25 AM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Have you performed a block test?
What was the original cause of the overheat, that caused head/head gasket damage?
If the original cause of overheat wasn't fixed, you'll replace that stuff over and over again it's finally corrected.
Old Aug 6, 2011 | 01:27 AM
3rdBird's Avatar
Magna flux and pressure test. ANY machine shop can perform that test for about $150 for both heads
Old Aug 6, 2011 | 10:18 AM
checker's Avatar
the cause of the overheat was that fan did not turn on so know its made to stay on every time i turn on the car.. if machine shop says its one cylinder head thats bad should i replace that one or the whole thing?
Old Aug 6, 2011 | 02:58 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
the thing is you dont know for sure it is a cylinder head problem. A shop told you this or what? I'd take it to a known good repair facility and see what they can come up with.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
