Northern California Discussion board for Northern and Central California.
What's on your to-do list before april 14th?
Old Mar 23, 2012 | 10:22 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
In order of priority for myself I need to get a new starter, this relatively new hitachi starter is not cranking at all when it gets hot even after a 5 minute drive its barely turning over. New one on order. I will be getting a DEI heat shield wrap with this one as well! Other then that I have a plugged outlet on my radiator thats about due to be replaced. I hate using those cheap rubber caps they show cracks way to early and I dont need one breaking on me at the track. I may run a hose off of it and make it plumb in the intake or something.
Lastly I want to get my mirrors painted and installed along with my hood being repainted so I have a little more of a complete car for race day
Old Mar 23, 2012 | 10:31 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
Re: What's on your to-do list before april 14th?
Replace the passenger side door and get her painted.
Old Mar 23, 2012 | 10:44 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
are you racing that day?
Old Mar 23, 2012 | 11:55 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
I need to burn my rear tires off.
Old Mar 24, 2012 | 12:17 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I said before, not during!
Old Mar 24, 2012 | 12:33 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
im doing a water pump for preventive. I have a brake squeak that comes and goes from the front brakes. so i will take care of that. and I need to tune more. I doubt that I will be racing. But I might be ready.
Old Mar 24, 2012 | 12:34 AM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I have the same issue man. Mine is a Powermaster mini I think, but too much heat that close to the header I believe. Bought some wrap too and hopefully that does it. Let me know if that does the trick for you.
Old Mar 24, 2012 | 12:37 AM
3rdBird's Avatar
Car: 91 Pontiac Firebird
Engine: Killer SBC, w/ RV cam
Transmission: AutoMatic, w/ shift kit
Axle/Gears: Posi-Traction
Dyno tuning on Wednesday.
Install parachute and chute release handle tomorrow.
Install window net tomorrow.
Fill up eight 15lb bottles of nitrous.
Install new carpet kit to make car resemble a normal car.
Install new slicks on wheels.
Load car on trailer.
Run a 9 second pass
Old Mar 24, 2012 | 12:48 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
I don't know what is up with these mini starters. I have more clearance with my ceramic coated long tubes then I do with an old obese starter hiding under iron manifolds. I will have my new starter installed either sunday or tuesday weather dependant. I am sure no difference will be noticed between then and race day. Will yours be replaced by the 14th as well?
Run a 9 second pass
Keep me posted on dyno numbers, off and on the sauce. What color carpet? Red I hope! I also hope to only be ~1 second behind you. rounded numbers of coarse your 9.x to my 10.x
Old Mar 24, 2012 | 01:02 AM
3rdBird's Avatar
Black carpet, to match the black plastic interior. It's like yours, it's starting to look like a real normal car.
Except for it's loud and runs about 140 mph in the 1/4.
Old Mar 24, 2012 | 02:23 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Nice, nice. Full interiors are the way to go. I am really loving driving mine. Feels like a normal car again minus the cam and blower noise.
Old Mar 24, 2012 | 10:17 AM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
i need to get my 700 shifting correctly
Old Mar 24, 2012 | 10:47 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
recently rebuilt? or whats going on vasquez
Old Mar 24, 2012 | 10:51 AM
not "recent", it was rebuilt about 3 years ago. i finally installed it last week. im "restoring" it. are you handy with 700's?
Old Mar 24, 2012 | 10:59 AM
3rdBird's Avatar
That's how they should have built em
Old Mar 24, 2012 | 02:56 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Some rewiring to finish, tune, smog, possibly brakes... It's gonna go to the wire. But I'm hopeful. Working outta town 5-6 days a week sucks sometimes.lol
Old Mar 24, 2012 | 08:12 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
no not really all that handy with them. so id assume its not as simple as the TV cable adjustment? Maybe you have a sticking governor....
Old Mar 28, 2012 | 06:17 PM
supamaro383's Avatar
Car: 92 RS
Engine: 383 FIRST TPI OBDII DBW
Axle/Gears: 3.73 POSI DISK
I need to bleed my brakes and get new tires for 16........I have 5 gen 20" but with 2" drop the tires rub every were
Old Mar 28, 2012 | 08:03 PM
Copchaser's Avatar
Next to the tires rubbing all over the place, that has to be an uncomfortable ride, huh? Dropped on rubber bands and limited suspension travel....
Old Mar 31, 2012 | 12:59 PM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
head gaskets and head machnining, wiring harness change, dash pad, center console, radio pod. probability of getting anything done equals 0 no time too busy at the shop
Old Mar 31, 2012 | 01:13 PM
unobetr's Avatar
Car: 1984 Z28
Engine: 383 stroker
Transmission: th350
Axle/Gears: 3:43
rebuilding my heads and new pistons and lots of tuning maybe the 28th in phx az fastest car shootout
Old Mar 31, 2012 | 01:31 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
He meant for our Nor cal gtg! But sounds cool. Would like to see some video of your car in the future!
Old Mar 31, 2012 | 04:44 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
You have two weeks. Get at it!
Old Apr 1, 2012 | 11:43 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
putting the car back on my insurance and going to the DMV to get my tags legit
Old Apr 2, 2012 | 12:09 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
so your going to be making an appearance Mr. Car of the month?
oh and for the record. I changed my front brakes, changed my water pump, and did an oil change so those 3 things are ready for the track. If I do in fact race. which is very unlikely at this point and time
Old Apr 2, 2012 | 09:18 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Why unlikely?
Old Apr 2, 2012 | 10:45 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Tune isnt right. And yesterday I sat around and did nothing all day instead of working on it. So it is unlikely I race.
Old Apr 2, 2012 | 03:55 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
You bum. Only marc and myself will be racing at this rate lol.
Old Apr 5, 2012 | 12:15 PM
91formula-fbody's Avatar
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
just got my heads back from the machine shop now gotta get it back together and make sure i have no other issues with it
Old Apr 5, 2012 | 06:04 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Sweet. Hope everything goes smoothly.
Old Apr 5, 2012 | 09:59 PM
Copchaser's Avatar
U are NOT setting a good example here Cartman!! u have a week to make some sort of progress.. no excuses!
time for a couple all-nighters. U can do this
Old Apr 6, 2012 | 12:40 AM
1TUF92Z's Avatar
Car: 92Z28,91Z28,91Z281LE,95ZR-1,08Z06
Engine: 406, 350, 305, 350, 427
Transmission: auto, auto, 5-speed, 6spd, 6 spd
Axle/Gears: all stock
I'll start Jolly to circulate the oil and possibly change it and I'll be working on my shifter karts.
Old Apr 6, 2012 | 01:06 AM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
Bennie you coming out on the 14th?
Old Apr 6, 2012 | 11:36 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
I do my best!
In cartman voice: "tuning is fukking bullshit, why can't it just run good by itself" haha
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Lbibb
May 5, 2016 12:00 AM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Dragonsys
Sep 25, 2015 03:51 PM
