NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
Shifting
Old Apr 3, 2005 | 03:05 AM
transram88's Avatar
Car: 88 Trans-Am 305 TPI, Yokahama dbs s2 front/ avs ES100 rear, Shift kit, K&N, complete 4th gen rear end, sun roof, 80's pinstripping, 4 point harnesses, memphis car audio
Shifting
Allright, here's the problem..... When a have the car floored, being that it has a shift kit, 1st to 2nd gear is an excelent shift at 5,000 RPM's.... But, if i keep the car floored, for some reason the car will go way into the red, and won't shift unless i let up.....any answers?
Old Apr 3, 2005 | 01:29 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Re: Shifting
No shift on the 2-3 means it's time for a rebuild.
Old Apr 3, 2005 | 01:39 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
Nape is right that is what mine started to do. It will drive forever like that but you cannot use it in a performance application
Old Apr 3, 2005 | 03:08 PM
9D1Formula350's Avatar
Car: camaro...????
Engine: 305ci of mouse power
Transmission: 5 speeds of fury
Old Apr 3, 2005 | 05:57 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Been there. Done that. Rebuild time.
Old Apr 4, 2005 | 03:18 AM
transram88's Avatar
even if it shifts like new when im not abusing it....whenever that is?
Old Apr 4, 2005 | 08:18 AM
nape's Avatar
Yep.
Old Apr 4, 2005 | 09:26 AM
transram88's Avatar
allright...thanks everyone
Old Apr 4, 2005 | 10:32 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
after my brother has rebuilt bills and his own tranny and taken aprt my tranny and pout it back together, go buy a good rebuild book , video optional, and get a good rebuld kit.. and do it your self if your mancaically savy.
if you take your time its not that bad.
it also helps to take digital picutes along the way and lable everything.
Old Apr 8, 2005 | 12:58 AM
85 roc it's Avatar
Car: 85 IROC
Engine: 385AFR head, Mini Ram Intake
Transmission: 6 Sp.
Its just the valve body in the tranny, my brothers GTA did the same thing, but after he replaced it, it only lasted about 50 miles.
Old Apr 8, 2005 | 02:20 AM
transram88's Avatar
if i let up the slightest bit it shifts, so i'll be alright. i let up enough to where i don't loose any speed
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
