NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
Winter projects
Old Dec 20, 2005 | 10:38 PM
novadk13's Avatar
Car: 92 Firebird,74 Nova
Engine: Stock tbi,Vortec 350
Transmission: T56, th350
Axle/Gears: 3.73 LSD, 2.73 open
Winter projects
Since it hasnt been asked whats everybody doing to the cars this winter? All I have lined up is fix the oil pump in the 88 and fix the drivers power window in the 92. Im spending most of the time on the pickup so unfortunatly the 3rd gens are on hold for now.
Old Dec 20, 2005 | 10:46 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
Stealthram install on the 91 RS. Rearend swap on the 90. Oh and find a T56 that can handle a 200 shot for the RS.
Old Dec 21, 2005 | 05:22 PM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
building up a th350 with a trans brake, installing sub frames, redoing the rear end (spool, gear, axles, so on) tuning the engine, getting a cowl hood, installing a roll cage and 5 point harnesses, and redoing the head liner and other interior parts......pending money quantities ofcourse
Old Dec 21, 2005 | 11:20 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Basically, just get the car running, install all the weatherstripping, the interior, stereo, gauges, the Moser 9" rearend, the front C4HD brakes and 1LE rears, STB, LCA's, panhard bar, etc. You know, little stuff.
It's all sitting here except for the rear brakes- just gotta get out in the garage and thrash.
Mmmmm.... 31-spline N-case 3.70 locker...
Old Dec 21, 2005 | 11:37 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have a laundry list of things to do...ie spending more and more money on the car, if i listed all the parts that are being added i'd sound crazy. plus finishing up jay's car as well.
Old Dec 22, 2005 | 01:11 PM
Camarothatcould's Avatar
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Basically get the L98 built and perhaps get the tranny rebuilt before april so I can have the ROC going before the summer. The rotating assembly is all done, internals balanced, crank polished, pistons cleaned and polished, block painted, intake painted. Just need to be built now.
Old Dec 22, 2005 | 03:06 PM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
-Save all the money possible so I have money for the first NASA event of the year
-Weld some patches into the floor and maybe a 6pt cage if I can find some out of date harnesses for a steal.
-Routine maintenance: check wheel bearings, brakes, steering, make sure all bolts are tight, etc
-Start stripping the new roller.
Old Dec 28, 2005 | 02:33 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
install sequential turn signal kit that my bro got me for christmas
Old Dec 28, 2005 | 09:17 AM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
I am in the process of building a Megasquirt II system that I got for Christmas. I also have a forged Scat 383 rotating assembly that is on its way and a new block that will get the machine work done this winter.
I will have the Megasquirt on the car and running this winter, but the engine won't be done until sometime in '07.
Old Dec 28, 2005 | 02:14 PM
always tinkerin's Avatar
Car: 85 Berlinetta
Engine: 408 SBC with a S-480 Turbo
Transmission: TH350/Hughes converter (Thank Pete)
Axle/Gears: 3:23 28.5" tire
Still looking for the items listed below. That will make a nice start!
Old Dec 28, 2005 | 05:40 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
New 17x8" wheels and tires along with a complete C-5 corvette front brakes package and LT1 rear disc conversion to get rid of the old drums on there now. Panhard bar lowering bracket to help with the geometry of the lowered suspension. Out of money now..
Old Dec 28, 2005 | 07:18 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
First thing on my list is deciding if I'm going to keep both cars come spring
Birdie needs a new trans and a dyno tune along with a bunch of small freebie/cheap things (just fixes and the like).
Z needs a rearend (might swap the one in the birdie), rebuilt the T-56, headers, cam, etc.
Old Dec 28, 2005 | 08:30 PM
Sleeper_Z's Avatar
Car: Golden yellow 1987 IROC-Z
Well I have a whole list of things I need to do. Priority #1 is either rebuilding the 10 bolt in my 94 camaro or "maybe" a 9 inch if the cash flow picks up. Then Id like to tear the motor down and install new rings, bearings, and oil pump (.030 bore if needed). But at the moment Im doing some free stuff to the IROC. Gotta finish porting the intake base, install the LT1 cam, put in the new trans, swap in the big brake 9 bolt with 3.27s, straighten the 1/4 out from the mail box incident, install the new passenger side fender from the same mail box, find some nice 4th gen seats and maybe just maybe get some fresh yellow paint on it.
Old Dec 28, 2005 | 08:35 PM
nape's Avatar
What should have originally been posted by DuronClocker
First thing on my list is to fix the rearend in the Z then take it to a NASA track day to drive the **** out of it.
There, I fixed it for ya
Old Dec 29, 2005 | 09:47 AM
Car: 1997 Corvette
We'll see. It needs a bit of suspension work to be any good though. Body roll feels a lot worse in this thing than in my bird.
Also, Jeremy, you'll have a PM in a little while.
Old Dec 29, 2005 | 01:59 PM
nape's Avatar
The first time out, body roll is the least of your worries. The biggest one is trying to get the smile off your face before it freezes and the second one is trying to unclench your butthole after you fade the brakes into a fast corner
Old Dec 29, 2005 | 06:40 PM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
Getting the valvetrain pieces together so I can take it all to Van Senus and get it all put together in one nice longblock!
Old Dec 29, 2005 | 06:43 PM
novadk13's Avatar
the hells NASA?
Old Dec 29, 2005 | 07:23 PM
nape's Avatar
Originally posted by novadk13
the hells NASA?
National Auto Sport Association.
NASA Midwest region = http://www.nasamidwest.com
They have lapping days where you can go drive your car on a road course with an instructor so you learn correctly, then you can drive by yourself when you're signed off or keep going and go for a competition license. My sig spells out my plans
tmellott89
Oct 14, 2015 02:06 PM
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
