NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
In need of running 305 or 350!
Old 01-09-2006, 06:15 PM
Moderator/TGO Supporter
9D1BURD's Avatar
Car: 1997 Z28
We need to pick up a running 305 or 350 we can just throw a tpi on and go.
Anyone have anything?
we need it like yesterday
Old 01-09-2006, 08:28 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'd sell the 305 out of my camaro for the right price but i have several hundred into it already. it's the motor i fired up at thirdgenfest, based on a 110 lsa cam not sure if that's tpi friendly.
Old 01-09-2006, 08:33 PM
9D1BURD's Avatar
Car: 1997 Z28
thanks steve, i dont think we can afford that for the project we are working on.
thanks again
Old 01-09-2006, 08:54 PM
xpndbl3's Avatar
Car: 1984 Z28
ok no problem, just figured i'd help you all out before i put in my real motor for next summer
what are you looking to spend on a motor and i'll keep you in mind?
Old 01-10-2006, 09:44 AM
AT9305RS's Avatar
Car: 91 Bird
Engine: 3.1 w00t
Transmission: 7hundo
Axle/Gears: bent
like really really cheap
under 300
Old 01-10-2006, 03:02 PM
xpndbl3's Avatar
Car: 1984 Z28
do you need a shortblock or longblock? i'll poke around the motors laying around and see what i have
Old 01-10-2006, 03:06 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
well, to make life easier, a long block. But whatever you have would be worth looking into for us.
thanks
Old 01-10-2006, 03:10 PM
xpndbl3's Avatar
Car: 1984 Z28
guess not i'll make a post later to sell it up
Old 01-10-2006, 08:48 PM
jimboc0's Avatar
I have an L98 with around 100k on it I could probably part with. It's just sitting in the garage. I bought it a month or two ago, pulled the heads to check things out and haven't touched it since. It should just need the heads put back on. I've got about $300 in it, so you could have it for that.
If you're interested, I can take some pictures for you.
Old 01-10-2006, 09:34 PM
AT9305RS's Avatar
Car: 91 Bird
Engine: 3.1 w00t
Axle/Gears: bent
some pictures would be awesome
Old 01-11-2006, 05:41 PM
jimboc0's Avatar
I e-mailed pictures to AT9305RS and 9D1BURD. If your interested, let me know....if not, good luck with the project.
Old 01-12-2006, 03:40 PM
AT9305RS's Avatar
Car: 91 Bird
Engine: 3.1 w00t
Axle/Gears: bent
PM sent to jimboc0
Old 01-17-2006, 11:42 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
i got a 305 out of a mid 80s monte.. about 70k. ran great when pulled, it was gonna go in a little jeep project i had, but sold that. so it sat... $150 you can take it. its a long block.
Old 01-19-2006, 10:21 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
a runner though well. I have a none runing complete 89 350 tpi.... needs some work about a saturdays worth
Old 01-19-2006, 11:28 PM
AT9305RS's Avatar
Car: 91 Bird
Engine: 3.1 w00t
Axle/Gears: bent
how much were you looking to get for it?
Old 01-20-2006, 12:09 AM
xpndbl3's Avatar
Car: 1984 Z28
if you guys are doing this on a budget i would think you'd want something that doesn't need a rebuild? since gaskets, bearings, rings, etc all cost a lot more money than a running engine would.
Old 01-20-2006, 01:32 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Spend a day at the junkyard.
Look for GM Goodwrench labels on the valve covers and check out the first one u see.
Preferably full size so u can try and pull the pan in the yard to check out the mains after you compression test it.
If it looks ok, yank it and run for like 150$
It can be done if you know what your looking for.
later
Jeremy
Old 01-20-2006, 07:57 PM
Engine: ls1, LB9
really what rings and bearings do you buy?
I think the junk yard is your best bet for a cheap "runner"
Old 01-21-2006, 01:12 AM
xpndbl3's Avatar
Car: 1984 Z28
i can pull out the list of parts if you're interested in buying it? otherwise i'm not going to waste my time.
Old 01-21-2006, 08:20 PM
9D1BURD's Avatar
Car: 1997 Z28
sorry steve, did not mean to keep you hangin. The search has been revised to a new car.
Old 01-22-2006, 08:19 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
under 300
Hey- I have a running 305 127k miles, no funky noises, just burns a lil oil- comes with stock ex. manifolds, Air system, and TPI baseplate, and flywheel- $175 you come get it, or $250 delivered w/in 4 hours
Old 01-22-2006, 09:36 PM
9D1BURD's Avatar
Car: 1997 Z28
sorry, we are picking up a whole car for about twice that, good luck selling it though.
jhawkeye
05-25-2022 06:33 PM
theshackle
03-05-2017 06:37 PM
Fast355
12-02-2016 06:33 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: In need of running 305 or 350!
