ok... yet another problem with motor!!!
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
feels like its missing while just cruising around ,but at wide open throttle it feels ok and comes alive ,any ideas on THIS problem?i know its got a mild cam but its not that. kinda feels like something not balanced .like a fan blade missing .yes ,i checked that all ready and its ok
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: ok... yet another problem with motor!!!
is there a carb on this? I was going to offer to setup the carb for you, but realized your over a hundred miles away. Did you check timing? how do the plugs look? Black smoke out exhaust? etc etc
Car: 84 camaro
brand new edelbrock plugs are new cap is new
have not noticed any smoke
Last edited by one wheel peel; Apr 1, 2008 at 06:59 PM. Reason: Automerged Doublepost
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Make double sure that one of the wires isn't burned on a header. Check the resistance on the wires too. Make sure they all check out to within a few ohms of each other.
Pull the plugs and make sure one of them isn't oil fouled, could be a badly sealing intake manifold.
Does anyone ever notice any oil smoke until the motor is terminal? Maybe have someone drive behind you to check?
Car: 1984 Z28
ahhh edelbrock there's your problem. go buy a 650 double pumper holley and it should run better.
Car: 84 camaro
ok ,well i swaped flexplates when i had it out of car and didnt notice that the 1 one motor was a weighted flexplate and i put on a none weighted one any chance thats is my problem? i hope so
Car: 1984 Z28
that would cause an out of balance so ya that could be the shaking
Car: 84 camaro
someone needs to confiscate my tools lol im allways getting myself in more problems when im done then when i started 1 step forward 2 steps back
Car: 1984 Z28
come finish my swap then
so far i've taken everything out and put it back again besides the shortblock...oh man.
Car: 84 camaro
ahhh. all better now lol it was the wrong flexplate after all.
theshackle
Mar 5, 2017 06:37 PM
