NW Indiana and South Chicago Suburb Looking for club members to have gatherings, cruises, and to help each other out.
Test and Tune help
Old Jul 14, 2008 | 05:45 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Test and Tune help
My buddys and I wanna take our cars to Route 66 for test and tune to have some fun. Im 16 and I dunno if theres a age limit. My car is completely stock with besides come exhaust and air intake. It says I have to pass NHRA inspection. Will I pass?
Old Jul 14, 2008 | 06:37 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
Re: Test and Tune help
if your car is stock and slow they wont even open the hood.. not to say my car is fast cause its stock as well but when i teched at GLD (i know its not rt66) they didnt check a thing
- with that l98 low 14's should be in order
Old Jul 14, 2008 | 07:57 PM
cam383's Avatar
Car: 89 and 91 Camaro RS
Engine: 350ci TPI and 305ci TBI
Axle/Gears: 2.73 One-wheel wonder
As long as the car is "safe" you should pass inspection. Battery secure, no major leaks, decent tires, etc. Different tracks have different rules too. A track I used to run at in Wisconsin required a helmet no matter how fast you ran but other tracks like GLD don't require one until you go faster than like 12 or 13 sec. I would check the website and if that doesn't answer your question, give them a call.
Old Jul 20, 2008 | 01:58 AM
87cmroiroc305ho's Avatar
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
nhra is more strict than gld, well gld used to be nhra , then ihra, and now nhra, and back in the day, origionally, anything went, now its tight rules, and you have to know what they are. get an nhra hand book, i know its not legal, but i dont suggest this, even thow we do it some time, get a radar, scan a back road, measure from a sign or something 2.5 miles on your odomitor, and run it from 0 till the 2.5, and count, if your over a certain time or speed, theyll get really strict, but stock, i think is 14, so you should have a problem, hope i helped
Old Jul 20, 2008 | 11:00 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
You'll need your parents there to sign a waiver since you're not 18. A helmet is never a bad idea as well. Must be snell rated, go to a motorcycle shop and purchase one.
Old Jul 20, 2008 | 11:27 AM
JCL91TRANSAM's Avatar
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
Are you able to use motorcycle helmets at all for racing in a car? Every time I try to use one at GLD I get hassled for it being a motorcycle helmet. They have even told my friend that he couldnt use it and that he had to get a different one and this motorcycle helmet was brand new and up to date.
Old Jul 20, 2008 | 08:42 PM
xpndbl3's Avatar
Car: 1984 Z28
it needs a snell rating like M2005 then it is fine. Just being DOT approved isn't good enough, it needs a snell rating. There has to be a sticker inside the helmet showing snell approval.
Old Jul 20, 2008 | 10:27 PM
Transmission: 700r
Thanks guys you helped me out a lot.
Old Jul 23, 2008 | 04:09 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I went to GLD a few times with my '88 when I was 17 and never needed anyone to sign for me. May have changed over the last few years though I suppose.
Need a helmet if you are 13.99 or better, but its a good idea to have one anyways
As mentioned above, battery hold down, fluid leaks, and tire tread are the most important things they'll check on a stock car. When they saw the BFG drag radials sitting in my back seat, they told me they wanted me to get a driveshaft safety loop, but let me go anyways (the car was in the upper 14's at the time).
The one time I sprayed my LB9 there, they didn't even see the kit under the hood, but it was hidden fairly well. Would've been hassled for that I'm sure as it was not track-legal/safe at the time.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
Johnoooooo
Sep 22, 2015 08:55 AM
eustodp
Sep 20, 2015 05:09 PM
R13_Braz
Sep 18, 2015 05:00 PM
