OLD Third Gen Fest Discuss plans for the IL gathering set for May 27th-28th.
List of things to do before the fest?
Old Feb 12, 2006 | 08:22 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
This is the first year my car really does not need anything to go to the party
I was just curious what kind of to-do list others have before the big day?
Old Feb 12, 2006 | 09:46 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
motor swap----edit....BUILD motor now that "Fresh" motor was junk-----done
tubular x-member---finished, and a-arms swap---done
spring swaps---done
re-wire car harness front to back--almost done
put in 5 point harnesses--almost done, tabs need to be welded up still
buy a helmet for the track--still waiting on helmet
then get jay's car running and help out firebird383 as needed as well. So I have 3 cars to finish up.
Old Feb 12, 2006 | 11:24 PM
intruder's Avatar
first i have to get mine back from paint, and then i have to completely reassemble the car, right now it's a bare shell inside and out.
install motor and trans
install dash and interior wiring
lca's
install interior
fuel tank and sending unit and fuel lines
refinish the wheel's
better stop i'm scaring myself lol should have it done with time to spare
Old Feb 12, 2006 | 11:55 PM
SOX 19's Avatar
Car: 88 Formula, 01 Tundra
Engine: 305, 4.7 V8 17mpg
I have some minor things to get done, a little bit of welding, spray the spoiler and the engine bay. Then give it a wash and wax! I guess I could get it done in a weekend, when I get time. My fiance opened a flower shop in Mokena last weekend, and then our wedding is in April, so by Mid-May I should be able to get some time to get around to it.
Old Feb 13, 2006 | 06:08 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
wash, wax, clean interior fill with gas, chairs coolers and other stuff... then hit the road.... might rebuild the trans first tho
Old Feb 13, 2006 | 06:35 PM
xpndbl3's Avatar
Car: 1984 Z28
i'm jealous tony...lol
Old Feb 14, 2006 | 12:32 PM
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
I still have to finish the stuff that I didnt get done for last year.
- Finish the 4th gen guages
- Finish the Ram Air Setup
- Redo the headliner
The only thing I got done since last year is put in a new clutch, so this year I can actualy get on it without it slipping like crazy.
Old Feb 20, 2006 | 10:02 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Originally posted by xpndbl3
...help out firebird383 as needed as well...
Thanks Steve. I'll try not to get you involved in my mess. If it gets to be late April and it's not done, you might get a call. On the other hand, if you're not tied up fixing your Camaro, I've got lots of beer and a heated garage...
My list:
About a weekends worth of odds-n-ends to get the engine fired.
Install 9-inch- assemble 95 Z28 rear discs to housing
Install new C4HD front brake kit
Install booster/master/prop valve
Install wonderbar, Eibach springs, LCA's, adj Panhard, STB, etc.
Install complete interior (nothing but the dash in there now)
Install weatherstripping
I'm sure there's more, but the list is already giving me a headache.
Old Feb 21, 2006 | 12:21 AM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
looks like build a new car. come on lottery
Old Feb 22, 2006 | 11:46 AM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
man i thought i had it bad, but a motor swap?? denny must feel special you 2 would do all that for him
i get to:
do the engine first oil change (DONE)
tune carb and ignition (DONE)
put a manual master cylinder in (DONE)
run line lock switch
rebuild my th350 (DONE and now having to redo )
get a driveshaft (DONE)
install sub frames
get new rear tires
get some sort exhaust on it (DONE)
put in hardened push rods and set the rockers (DONE)
break the engine in completely (DONE)
get a hood (DONE)
and if money and time are there, install a 6 point cage (not close)
so fun times for me before the fest
Old Feb 24, 2006 | 10:21 PM
91RedRagtop's Avatar
Car: 1991 Firebird Convertible Horsepow
Engine: 406 w/Motown 220 heads
Transmission: 5 speed manual
Get this damn 406 in . I've had it for over a year now . Just need to buy some pistons and install it . And some sub-frame connectors to add on to the stock vert ones . New paint will have to wait a year at least . And Tony Walch , you forgot your most important thing , buy beer
Old Mar 29, 2006 | 05:28 PM
intruder's Avatar
FINALLY !!!! my car is done, paint turned out super, all i'll need now is gas and a final cleaning. ready for the fest
Old Mar 30, 2006 | 03:47 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Lets see.
Things that are new since the last third gen fest I was at (2004) --
New engine (TPI 350)
Trans built by Jimmy
New paint Job
LS1 brakes and total front end rebuild
Things to do --
Get car from Jay.
Install GFX (wet sand and buffed)
Clean the hell out of the car (all that old paint is all in there in dust form)
Put the car back together door handles, fog lights, emblems...etc
IROC-Z stripes
ALL the Weatherstriping
Sub Frame conectors
Things I would like to get done but most likey will not have the time--
Install 9 bolt with pbr rear brakes. (need new PV)
Hooker 2210 Long tubes and Y pipe with a custom cat back
Srtip and repaint my rims
Kevin
Old Apr 1, 2006 | 12:09 AM
jay92,85,79's Avatar
Car: 85z28,
man I don't think i have enuff time all the stuff i have to do.....
get gearheads car done
get steves car wet sanded and buffed
help him get the windows in there
Now for my car get running
repaint jams and all
put new seats in
i think that enuff for now
Old Apr 2, 2006 | 12:45 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I have to prep both of mine:
IROC:
Get my racing exemption for emmisions & register the car
Install new AFPR
Replace all the steering linkage
Find out why the engine is tapping and fix it
Formula:
Find, rebuild and install a 350
Patch the drivers side floor pan
Install new t-top & door weatherstripping
Install new exterior locks all the way around
fix up the interior
Get the paint on the nose touched up
Thats just the stuff off the top of my head. Good thing I have a shop or I'd be screwed.
Old Apr 2, 2006 | 02:33 PM
Half-FastRacing's Avatar
Car: 89 IROC-Z
Engine: L98 - Stock
I have a lot of nitt-picky things.
As is, the car will drive and make it to the fest. All the nitt-picky things would be gravy.
Get windshield wipers working
Get HVAC working
Replace fender and front clip
Push-pin headliner
etc
Old Apr 16, 2006 | 11:15 PM
Twisted92Z28's Avatar
Car: 1992 Z28
Engine: 5.7L 350 TPI
running out of time, still so much to do
wait for my Eibach Sportline Lowering Springs and Hotchkis Sway Bar Kit to arrive then find the time to put them on, and be alot closer to my money goal for my other mods i have in mind and maybe even have some by time thirdgen fest comes.
Old Apr 25, 2006 | 11:40 PM
xpndbl3's Avatar
Car: 1984 Z28
motor swap----edit....BUILD motor now that "Fresh" motor was junk.
build 350 combo---started 4/26/06----done and cam broke in
tubular x-member, and a-arms mounted---finished
spring swap--done
install rear sway bar
install 3.5" custom aluminum driveshaft
re-wire car harness front to back-almost done
put in 5 point harnesses--waiting on welded tabs to cage
buy a helmet for the track--$350 here i come
Old Apr 26, 2006 | 09:53 AM
Car: 87 Iroc Z28
Engine: 355 TPI
I haven't gotten anything done yet, mine will most likely end up coming the same way it was last year. Oh well, maybe it will all be done for next year.
Old May 12, 2006 | 04:33 PM
GarageToys's Avatar
Originally Posted by Firebird 383
...If it gets to be late April and it's not done, you might get a call...
Ring Ring!! Ring Ring!!!
I'd love to have your assistance if you have time. Pretty much for the last 2 months all I've done is go to work, sleep, and work on the car. I've even cut the sleep time down. My wife came out to the garage to get me at 4am on Wed Night (Thurs morning?). Yes, it sucked being at work 3-1/2 hours later. Anyway, if you get yours done with time to spare, give me a shout.
Old May 12, 2006 | 05:28 PM
xpndbl3's Avatar
Car: 1984 Z28
alright, next week i'll run out there sometime to give you a hand. hoping to get my car to jay's during mid week to have him wetsand/buff my car and put the rest of my windows together. then hopefully fire up his car as well, that'll be trailer rental #1 for me, then #2 will be thirdgenfest. monday i'm supposed to wire up daturbosix's car if he finishes everything else this weekend, so who knows. tomorrow jay's supposed to weld in some harness tabs for me, i've been fighting this cold for quite a few days now too, trying to sleep a lot and get over there. today's the 12th, you have officially two weeks to finish 'er up kev....i'll give ya a hand next week for sure.
Old May 12, 2006 | 11:19 PM
i need to REDO the trans I just built and then burnt up because it leaked all the fluid out in the last 3 blocks to my house.....another $150 in clutches and steels here i come!!!
Old May 17, 2006 | 02:56 PM
CogsRS's Avatar
Car: 87 Monte Carlo SS
Transmission: 200 4R
Wow, everyone's got problems. I have to do...NOTHING. Cause I don't own a third gen anymore. I've been helping out my friend Tom to get his 88 GTA going before TGF.
His list...
Install engine/trans/driveshaft,
remove fenders, nose and door,
sand, prime and paint everything,
install door, fenders nose and hood.
If there is time, it might get wet sanded and buffed.
I might drive my '87 Monte SS there if I have somewhere to be after. If not, I'll ride with the GTA.
Old May 17, 2006 | 05:12 PM
SOX 19's Avatar
You're gonna have all that done in 10 days? Wow!
Old May 18, 2006 | 09:13 AM
Woo hoo !!! My 406 is up and running . Finally . Now just a few tweaks , and I can get it inspected liscensed and plated . Should be able to make it after all .
deracer
Apr 11, 2016 12:04 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
Linson
Aug 21, 2015 02:12 PM
Bob88GTA
Aug 18, 2015 03:31 PM
